what do i need for my nitrous?
Car: 92 trans am clone
Engine: LO3
ok i have brand new ac delco rapid fire plugs can i keep these or do i have to buy autolites or NGKs? also should i retard the timing if so how much? ill be running a 125 wet shot on my LO3 auto. anything else i need to know?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
125HP = ~4* retard the timing, and run 91 octane minimum of course.
Maybe 1 heat range cooler, brand doesn't really matter. R44 or R43TS
How about trying whatever the N2O setup’s manufacturer recommends? For example, NX will recommend 1-2 heat ranges cooler plugs and no timing retard for that 125 shot… others recommend 1-2* retard for every 50hp… and they all use slightly different jetting for the same power level
Engine: LO3
im afraid not to retard timing cause i only got one shot and if i blow im out of the game completely with a different car
CarGuyDennis
137
Dec 6, 2016 11:02 PM
FlyinLow89
Nov 12, 2001 02:35 AM
vortech305
Mar 30, 2001 12:21 PM
