supercharger
Old Aug 13, 2006 | 09:18 AM
monoply6's Avatar
Car: 89 trans am gta
Engine: 5.7
Transmission: auto
Axle/Gears: 9 bolt
supercharger
hi all could any one recomend a supercharer kit that does not need to run an ic , i dont want to change my hood its a 5.7 tpi gta im looking for around 300 hp mark if possible, what can the engine take power wise with stock internals
Old Aug 13, 2006 | 12:15 PM
Drac0nic's Avatar
err, don't take this the wrong way but if your power goals are in the 300 range (even 300rwhp) I would probably end up just taking the money and spending it on engine work. I'm not trying to discourage you from a supercharger, just saying that you'll probably make more power then you think. You can probably get there for half the price of a S/C if all you're looking for is 300 N/A HP.
Then again, an L98 should be able to take quite a bit more then that, provided you can tune it. Keep in mind that people spray a 150 shot on L98s all the time, which means that even with a stock 245hp L98 you'd be near 400 at the flywheel.
InfinityShade
Feb 21, 2016 01:29 PM
toronto formula
Nov 10, 2015 06:17 AM
-=Z28=-
Sep 24, 2015 10:21 AM
anesthes
Aug 24, 2015 08:32 AM
PestilenceIV
Aug 20, 2015 03:32 PM
