Blown (literally) Procharger
Old Aug 21, 2006 | 08:39 PM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
Two nights ago my Procharger grenaded. It was a P600B and it looks like it nuked a bearing. The problem is, as these units are not self-oiling, it dumped metal shavings into the oil pan via the oil return. I ripped the belts off and rerouted the intake (because there was metal being blown into the charge pipes as well) and changed the oil after driving it approximately 3 miles from the point of destruction. Unfortunately I didn't yet disconnect and cap the oil feed and return, so after driving it less than 500 feet the oil pan is full of metal shavings again. I won't make this mistake twice, tomorrow I'm capping the oil lines and removing the head unit and changing the oil AGAIN.
I'm making this post for three reasons: one, to inform those using prochargers that if they grenade they will dump metal into your intake (and oil pan if you have a 600B) two, to ask how many oil changes is it going to take to get this crap out of my engine, and three, since I'm running full synthetic would it be okay to run dino oil through it for the next few changes to flush it out? (synthetic is getting expensive)
Old Aug 23, 2006 | 02:11 AM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
wow man that sucks.......trying using some motor flush......you just dump it in, run the engine for a minute at idle, then change it......it shouldnt matter if its in the bottom of the pan, depending how big the pieces are. If the pieces are too big they'll get stuck to the pickup screen, if not the only thing they go through is the pump, then the filter before they can go through the motor......hopefully the magnetic plug pics some up too.
its perfectly fine to switch from synthetic to regular oil and back again......all the not mixing synt/conventional oil crap is a myth.......what do you think synthetic blends are made from? lol.
Old Aug 25, 2006 | 01:20 AM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
Changing oil just for flushing is not going to hurt it at all
although it has been proven that if you run syn. then switch to conventional and run that for many miles and then back to syn. again you can run into some problems. It all depends on how many miles are on the motor and what condition it is in. Most people make the mistake and dump syn. into a 75k motor that has always ran conventional and then they wonder why there engine is using oil and a faster rate then it was before.
Old Aug 25, 2006 | 07:43 AM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
After four oil changes there's still trace amounts of stuff on the dipstick, looks like glitter now though. I'm on my way to have some work done and have it changed again this morning. The motor has about 10k miles on it (was purpose-built to run large amounts of boost) so I'm hoping it holds up.
Old Aug 26, 2006 | 12:00 AM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
Mna thats sucks did it make a loud band when it went out or did it go quietly
Old Aug 26, 2006 | 01:08 AM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
What did procharger say?
Old Aug 26, 2006 | 06:15 AM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
I didn't even bother calling ATI. Frankly I'm appalled this design ever made it out the door.
And my motor is shot. Oil pressure is near zero at idle when warmed up. Time for a rebuild.
jrdturbo
Mar 31, 2016 02:58 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
usafirebird
Sep 29, 2015 11:58 PM
383backinblack
Sep 25, 2015 11:31 AM
