Upgradeable nitrous plate kits psbl?
Old Aug 26, 2006 | 11:56 AM
WinnipegGTA's Avatar
Car: 1991 GTA
Engine: 5.7L L98
Transmission: 4L60
Are either the NOS or Nitrous Work TPI plate kits upgradeable from there as is ratings. I see you can get them from i think 50-150 and 50-125 but what if you wanna go to a 200 shot or something like that can these plate kits support that.
Old Aug 26, 2006 | 04:09 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Having owned both of these I can tell you that NOS says there plate will support a 200 shot, The Nitrous Works plate only has 2 outlets per bar so it probably won't even flow the full 150 shot. Personal opinion, the NOS part is a MUCH better plate.
PS NOS says there solenoids with the 5151 kit will flow a 175 shot, NOS also rates there jetting much lower than TNW (TNW says a 63 jet is a 150 shot, NOS says a 70 jet is a 150 shot, both whp). The TNW plate I had also used compucar jets and the only jets I had for it were simply numbered 1 2 3 4, not sized like they should've been.
sailtexas186548
Jan 19, 2016 12:21 PM
mhatfield 14
Oct 24, 2015 07:48 AM
gixxer92
Sep 1, 2015 04:32 PM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
