any needed mods to MAF?
Old Sep 17, 2006 | 03:01 PM
camaroracer85's Avatar
Car: 1985 chevy camaro iroc-z
Engine: 350 currently gettin built up ask?
Transmission: 700r4 with holeshot 2400
Axle/Gears: 3.23, thats stock i think???
im new to this supercharger stuff. Im trying to buy a procharger for my car. What kind of mods do i need to make? I found a chip that will work. How do i run the MAF sensor with the SC. Any other sensors need to be modified? Thanks
Old Sep 17, 2006 | 11:17 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
Ive been wondering the same thing I know you could convert to speed density, but If your like me you probaly dont want to hassle with that
Old Sep 17, 2006 | 11:36 PM
firstfirebird's Avatar
Don't quote me, but in the forced induction world I believe your computer can handle 6psi without changing anything, if your running more than that...
Old Sep 18, 2006 | 09:01 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
A 350 running 6lbs of boost is pushing about 653cfm, the stock MAF sensor can flow up to 658cfm. I would think that anything over 6lbs is going to need a modification.
Old Sep 18, 2006 | 10:12 AM
would that just mean getting a bigger/after market MAF sensor? Any other mods?
Old Sep 18, 2006 | 11:31 AM
There are a few options that you can do. The cheapest would be to re-pin the harness for a Speed Density system (730 ecm or 749 ecm).
Upgrade from: 1985 ECM 870 --> 1986-1989 ECM 165 (My 85 Z28 and EPROM Project)
Upgrade from: 1986-1989 --> 1990-1992 ECM (speed density) 730 (My 85 Z28 and Changing a '165 ECM to a '730)
Upgrade from: 1990-1992 ECM --> 749 Syclone/Typhoon ECM (https://www.thirdgen.org/1990conversion)
The speed density 1 bar system can handle up to 12lbs or 15lbs (maybe someone else can answer), with the 730 & 749 ecms, a hack can be programmed to run a 2 bar map system which will handle boost up to ~20lbs.
Old Sep 18, 2006 | 12:00 PM
What would be the best upgrade for 8-10 lbs of boost?
Old Sep 18, 2006 | 12:18 PM
I'd just go to 730 ECM and get a chip.
Old Sep 18, 2006 | 11:47 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
I don't consider the factory MAF a restriction unless you are pushing 400+hp.
That said, I've got a Granatelli Adjustable MAF.
It advertises 30% more airflow over stock and I'm hoping it will come in handy if I decide to use a supercharger in the future.
IROCZ1989
Jan 24, 2016 03:55 PM
NBrehm
Aug 25, 2015 11:49 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
