4.3 vortec tt help
Old Oct 20, 2006 | 03:11 PM
daves12secV6's Avatar
4.3 vortec tt help
well ive goten my turbos,wastegates,bovs,intercooler picked out.
ive got a set of h-beam rods,and forged dished pistions (8.5-1)on the way.
but now that ive looked into the 4.3 motors a lil more,these things are producing some serious numbers on relativley low boost.Hell the place im ordering my heads from has an 1,200 hp 4.3 votec,and there making that @ 20 psi . Lol my 3.1 made 412 at the same boost levels pretty much.So now im stuck on what to do with the crank,they sell a crank kit but it runs almost 3k,any of u guys know anyplace that sells forged 4.3 cranks.
anyone also know what a stock 4.3 block is good for in terms of power levels?.i already knwo im gonna end up doing a half fill on the block
cause right now its looking like my goal of 600 rwhp is gonna be blown away.and after talking with these guys about my heads,there saying i should make more around 725+.
and the last ? is will a sbc gear drive,or belt drive work on the 4.3
Old Oct 20, 2006 | 10:28 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Those HP figures are possible. Did you ask them what they rev. the 1200HP up to? Ira at turbomustangs makes about 1000HP on a race setup 358ci 8 cyl with good heads (AFR?) and a 85mm or 83mm turbo revving to 7500 RPM at 20+ PSI. His turbo is good for 1200+ HP. What are you planning on revving that 4.3 up to? I am not knocking the setup just trying to be realistic.
Old Oct 20, 2006 | 11:30 PM
there taking there motor upto 7,800,its a twin turbo setup.id like to take mine up that high but its not gonna happen.ill prolly get 6,5-6,800 out of mine maybe a lil more.and i made a mistake the 1200 was @ 24#'s not 20.right now im worried about finding a good crankshaft,cause i deff cant afford there cranks they start @3k.
Old Oct 21, 2006 | 02:20 AM
83blackmaro's Avatar
your gonna put a 4.3 vortec motor in your camaro i was actually contemplating that still undecided as to what i wanna do stay 6cyl or go v8...are you makin the mounts for the vortec motor from scratch or ordering them from somewhere?
Old Oct 21, 2006 | 05:08 AM
junkcltr's Avatar
Engine: 3xx ci tubo
That sounds much better, 8K and 24PSI will get to 1200HP. You will also be right up there in HP. Sorry I can't help with the crank.......but this is getting bumped to the top for more people to view. Yeah, 3K for a crank is tough to swallow. Almost worth doing a cheap V8 at those prices.
Old Oct 21, 2006 | 03:05 PM
yeah it is but i still cant see doing a sbc with a twin turbo the way i want it done and make the power i want for 3k,besdies the fact i said i would never drop a small block in the car,lol it will always a v6 in it
Old Oct 21, 2006 | 04:10 PM
TurboedTPI's Avatar
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
Im pretty sure the timing chain setup is identical to a sbc.
Old Oct 22, 2006 | 12:33 PM
yeah it is i just verified it myself,looks liek ill be springing for a belt drive for the 4.3
69GTOby
Apr 18, 2016 02:34 PM
Chas91Z28
Oct 22, 2015 10:12 AM
Quzyle
Oct 15, 2015 03:35 PM
monte87cortez
Sep 26, 2015 08:10 PM
Liveaction
Sep 17, 2015 06:29 PM
