stroking a camaro 305!!!!!!!!!!!!!!!!!
Old Oct 25, 2006 | 05:30 PM
bilyrocker33's Avatar
Car: 1985 Sport Coupe Camaro
Engine: 305 4 Barrel
Transmission: Stock
Axle/Gears: Stock
how far can you stroke a 305, like to a 334, 383 or anything to that extenet and what would be the costs, best parts, and what tools i would need to do it my self, and how much it would cost to get it professionaly done. thanks
My Ride
1985 V8 305 Camaro Sport Coupe T tops
Current Mods
none at the moment just bought it
Old Oct 25, 2006 | 05:58 PM
daves12secV6's Avatar
340ci is the max.i had a stroked 305 in my 86 iroc it was alright nice tq down low but really lacked anything up high,though it still had stock heads and cam on it pretty much.cheaper to go buy a 350 from the junkyard and freshen the motor and drop it in
the stroker crank is pretty cheap,but ull have to get new pistions made for it which can be cheap to really exspensive
Old Oct 25, 2006 | 08:21 PM
Transmission: Stock
Axle/Gears: Stock
ahhh
but how much will a 350 cost me at a junkyard then? and what about engines similiar like a 383?
Old Oct 25, 2006 | 09:28 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Try another section, this is for power adders(nitrous, turbo, and superchargers)
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Check around in your local area. Also, check the newspaper, and search the net. Make sure when you go to check out an engine, that you know how to positively identify the engine as a 350.
Old Oct 25, 2006 | 09:29 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
a 383 is a 350 with a 400 crank. they are a dime a dozen laying in junkyards and fields everywhere, but many late 70 and 80's 350 stock dont make much power.
Old Nov 10, 2006 | 03:45 PM
83 Crossfire TA's Avatar
Well, I’ve always thought a 349 would be cool (305 block bored .060” over with a 3.85” stroke crank like you would use on a 396 build out of a 350), but it is not the cost effective way of building cubic inches. It would make very nice engine in something that you’re looking to maximize efficiency (MPG for the amount of work done, like a truck that actually gets used as a truck), or in something that detonation resistance is a big deal with like a boosted engine, with some interesting consequences with newer fast burn technology, but that is not what interests people around here…
Jake_92RS
Jan 28, 2020 10:37 PM
jklein337
Sep 19, 2018 06:23 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
