Non-intercooled Vortech
Old Oct 30, 2006 | 08:35 PM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
Okay, another crazy idea I'm tossing around. After having bad luck with a procharger a few months back I'm in the process of buying parts for a rebuild of my motor and I'm starting to think I won't be happy without a blower on it. So I'm considering the base SQ-trim. I was less than impressed with the intercooler setup on the ATI unit and I've since sold it all, but I do have meth injection. My main question is compression ratio, both dynamic and static. What should I shoot for if I want to run 6-8psi of boost with meth injection? I know this is mild boost, but with the heads, cam and intake highly upgraded I should be able to put some nasty numbers to the ground. I 'm thinking somewhere in the 9.5:1 static ratio since I'm running aluminum heads (AFR) and a milder cam (comp cams 08-304-8).
Old Oct 31, 2006 | 09:21 AM
Ol'Blue's Avatar
Car: 1987 Trans Am
Engine: 383
Transmission: TH400
Axle/Gears: 9 bolt 4.11
Ima talk to your wife today and have her hit you in the head! lol
anesthes
Sep 30, 2015 07:48 AM
c350b
Aftermarket Product Review
Sep 26, 2001 07:28 PM
Chris Etemadi
Apr 25, 2001 04:46 PM
Dan87IROC-Z
Apr 4, 2001 08:13 PM
LilJay
Oct 25, 2000 07:59 AM
