Need Help Building an engine
Old Oct 31, 2006 | 07:18 PM
TransAm90GTA's Avatar
Car: 1990 Trans Am Gta
Engine: 350 5.7
I Have a 350 block that im going to drop in a trans am that i need to build from the ground up because i want to put twin turbos on it. Im getting forged pistons and a racing cam and carb but dont know what else i need for it not to blow up because im new at this.I also would like suggestions on what brands to put in. any help would be appriciated thanks
Old Oct 31, 2006 | 07:43 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
ooh, if you're new at this, a TT motor is gonna be biting off more than you can chew IMHO.
you'll need a forged crank, good main bolts/studs, H beam rods say, good rings. More specifications than "a racing cam". In fact, a non racing cam might work best, or a custom ground one.
o-ringed heads maybe. Big chamber heads, etc.
Old Oct 31, 2006 | 10:15 PM
GodSpeedGTA's Avatar
Car: 1989 GTA
Engine: Future: LSX Turbo
Transmission: built T-56
it all depends on what you are willing to spend
eagle makes nice forged cranks
you could go with a fresh bore and turn your 350 into a 383.
H beam rods are easy to find
as sonix said a more mild cam works best in FI situations
Youll need a turbo kit or build it yourself
youll also need a different ecm or stand alone fuel system
keep searching and researching and youll find a ton of info on this site
italiano67
Dec 11, 2016 09:21 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Reddeath210
Oct 6, 2015 08:20 AM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
