Blower and engine question
Old Nov 2, 2006 | 01:31 AM
Fromaster's Avatar
Car: 86' camaro
Engine: 305 (currently swapping 454)
Transmission: 700r4(currently swapping th400)
Axle/Gears: stock
hey all, whats the difference between a 6-71 and an 8-71? would this rotating assembly handle one of the blowers? http://store.summitracing.com/partde...5&autoview=sku thanks for any help
Old Nov 2, 2006 | 04:50 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
An 8-71 is bigger
So, this is planned on a 383?
It says "cast steel crank", then "forged crankshaft". I'd want to know which it is. I beam 5140 rods are good.
This should be ok with a 6-71. Main thing is, 12cc dish pistons. Watch the CR, using a blower like that you probably want bigger dished pistons to get the CR low enough to use a roots blower like that.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
