Programers and chips
Old Nov 6, 2006 | 05:40 PM
white87iroc's Avatar
I didn't know which section to fit this under, but this one seems the best. I was wondering what programer and/or chip to get for my 87 5.0 camaro. Little mods done. I don't know but i was hope you all did. Can you point me in the right direction?
Old Nov 6, 2006 | 11:35 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Check out Transtronics electronics Toshiba PLC-automation-ladder logic-process control Computer test equipment or Welcome to www.moates.net! : Moates.Net or willem.
I used the xtronics one for years. It is a good cheap unit. Download tunerpro to edit the chip. Then you program the chip with the programmer that you buy.
Check out the DIY PROM board for much more info. Read the stickies over there. They go into more detail of the things you need.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
ULTM8Z
Oct 2, 2015 01:25 PM
