when is dynamic CR too low?
Old Nov 20, 2006 | 01:19 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
I was using this cool program that tells me dynamic and static compression ratios after i type in a million things about the engine it seems, so it seems pretty accurate. I am getting a 6.9:1 dynamic CR, and a 8.8:1 Static CR. Is this too low for a 15 or even 20psi setup?
Should I go smaller cam ? 230/236 duration @.050" or smaller cylinder head chambers? This is with 75cc chambers, I can do 65cc.
Old Nov 20, 2006 | 08:35 AM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
Call Comp cams (or whoever your cam manufacturer is) and ask them to recommend/grind you a blower cam. My guess is it will be a bit smaller than what you are looking at.
Falcon50
Aug 22, 2020 03:26 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
