Help: Vacuum lines for BOV and WG
Old Nov 24, 2006 | 06:14 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
Got a question for you guys.
My wastegate has a Vacuum nipple and a Boost nipple. I hooked the Boost one up to the charge pipe so Im sure thats right, and I have the vacuum hooked up to the intake pipe before the turbo, is that correct?
Then on my BOV there is a vacuum nipple, should this be hooked up to the intake pipe before the turbo or to the plenum of the TPI?
Thanks,
Matt
Old Nov 25, 2006 | 11:35 AM
vwdave's Avatar
Thanks,
Matt
BOV should be hooked up to the plenum of the intake. Just a straight hookup.
As for your wastegate, Ive only hooked up 1 side. Just hook up the charge pipe to it and see which one gives you correct boost. One wont.
Old Nov 25, 2006 | 02:08 PM
Ol'Blue's Avatar
Car: 1987 Trans Am
Engine: 383
Transmission: TH400
Axle/Gears: 9 bolt 4.11
The nipple welded onto the charge pipe goes to the side port on the wastegate.
Also remember the 9-13 spring was in the wastegate and it was tightened to pull on the upper scale..
The BOV was hooked to a port on the side of the Throttle body.
If you want to run the PCV it needs to be ran from the PCV valve to the suction of the turbo.
Your just about to have some fun arent you lol
Old Nov 25, 2006 | 03:51 PM
MattODoom's Avatar
Car: '88 G T/A
Hey, I changed the spring over to the 5-7 spring and loosened the allen key out to 5psi. I have the boost side of the wastegate hooked up correctly, but what about the other nipple on the wastegate labeled Vacuum? Did you leave that disconnected?
Ill have to reconnect the BOV to the plenum as right now I have it hooked up to the turbo suction.
I welded a bung into the turbo intake pipe and am running the PCV that way with a breather on the pass side, seems to be working great... car sounds awesome.
Old Nov 25, 2006 | 04:03 PM
Ol'Blue's Avatar
Car: 1987 Trans Am
Engine: 383
Transmission: TH400
The top port of the wastegate is used if you have a boost controller, which is a bad idea when learning to play with turbo's....just leave the top port vented to the atmosphere.
gta892000
Aug 11, 2019 11:16 AM
camarohelp
Sep 12, 2015 05:45 PM
Doobie52
Sep 11, 2015 06:19 PM
IROCtometal
Sep 9, 2015 10:01 AM
snakeshooter
Sep 7, 2015 11:13 AM
