Fuel setup options
Old Nov 26, 2006 | 07:06 PM
87IROC350's Avatar
Engine: 5.7
Turbo fuel setup options - need help
I've been debating going with a twin in tank pump setup. I picked up a LS1 tank I was going to try and use but I'm not thrilled about he fuel line size. I'm targeting ~800-900hp when my setup is all together. I see the stock fuel lines being a bottle neck coming out of the tank. I'm running 10AN from tank and 8AN return. I think the lines coming out of the tank is only 6AN so what's the point of running twin intank pumps?
As an alternative I was thinking of running a Walbro 340 intank and welding in a sump into the stock tank that I could use to plumb an external pump which would switch on around 5lbs boost. The intank would provide good reliability without too much noise and the external would just kick in under boost. This should allow me to run larger fuel line coming from the pumps to leverage their full potential.
I really liked the twin intank concept but I don't know how beneficial it is pushing through the stock tank fittings.
Any thoughts, comments, or alternatives for street/strip duty?
Old Nov 27, 2006 | 06:00 PM
87IROC350's Avatar
Engine: 5.7
bttt
Old Nov 29, 2006 | 06:58 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I am in the same boat. I was tossing around the idea of the dual intank as well. I ended up getting a Walbro GCA758-2 255LPH High output pump for 85-92 GM. Hope it works for me too . I plan on a fair bit less hp ( 650 hp when said and done) I am no at a point of trying how to manage it all ....Mega squirt , 749 ECM , FMU . What are you going to use ?
Old Nov 29, 2006 | 03:12 PM
87IROC350's Avatar
Engine: 5.7
I picked up an XFI w/ 83lb injectors I plan on using. The dual intank may work out nice for the HP range you are shooting for. You might find you are able to get away with still using the stock lines.
Old Nov 30, 2006 | 10:09 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Yeah I think I can get away with the stock lines. XFI? Is that the fast setup ? How much did you pay for it ?
Old Nov 30, 2006 | 05:10 PM
87IROC350's Avatar
Engine: 5.7
I found a decent price for it on ebay w/ wideband. Same guy selling in the attached link and he was pretty good to deal with.
http://cgi.ebay.com/ebaymotors/FAST-...spagenameZWD1V
Old Dec 4, 2006 | 05:21 AM
87IROC350's Avatar
Engine: 5.7
bttt..... c'mon no comments on fuel system recommendations?
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
Infested
May 22, 2018 11:56 PM
italiano67
Dec 11, 2016 09:21 AM
