Boost possible with 10.7:1?
Old Nov 30, 2006 | 09:42 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
On my 383, Lunati and JE bottom end, rated to 900 hp and 8k RPM, AFR 210s ported to the moon and back, running on megasquirt. I want to go TT, what size turbos would I need? I can get 110 all over around here, but could I turn the boost down and run 93? it was intended to be N/A and 93 with no probs. wanted 500 rwhp. maybe its just a pipe dream and i should stick to my original plans
Old Nov 30, 2006 | 10:49 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
I just recently went through this on my 10.7:1 cr engine, I have found its not really going to be benificial at all. I in fact tore down my engine and am redoing it for 8.7:1 which is a pretty common low compression number I have found for 383's
Old Dec 1, 2006 | 12:54 AM
Cerberus2k7's Avatar
Car: 99 Ford Ranger
Engine: 3.0 Flex Fuel V6
Transmission: The kind you have to change by hand
If youre running a high CR, then boost will be very low. I would say roughly 8-10psi on a T3 unit. If you really want boost, get cams that are designed for it, and a lower CR if you really want the power.
Old Dec 1, 2006 | 01:33 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
bust out the nitrous and skip the boost for when you build an o-ringed block for big numbers and low compression
Old Dec 1, 2006 | 06:59 PM
vwdave's Avatar
That and a aftermarket block.
Possible? Yes.
Smart? No.
Old Dec 1, 2006 | 07:15 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
thanks for the input guys. ill guess ill just spray the light house at it until it goes then ill build a TT 377
Old Dec 1, 2006 | 07:24 PM
vwdave's Avatar
How about you just mail me your engine, that way you have a reason to build it.
Old Dec 1, 2006 | 07:54 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
meh, i think itll take 250 for a while. id go more, but i dont wanna go direct port
Old Dec 2, 2006 | 10:39 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Good choice on using the N2O instead. In order to use the 10.7:1 CR you would have to throw a giant cam in it to leak down the cyls for normal street use but then the cam would be too much for the street. Race gas and a huge intercooler would also be needed.
Old Dec 3, 2006 | 06:30 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
probably meth injection too....
Old Dec 3, 2006 | 01:29 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
if your heads weren't so AFR-ish and "ported to the moon and back", i would say get some heads with 76cc combustion chambers and some MLS head gaskets.. then boost it up to about 12-15lbs intercooled.. i assume you have the heads with 66cc combustion chambers.. so a 76cc will bring you down to about 9.6-9.7:1.. but thats just a thought.. i would stick with the AFR's and nitrous the crap outta it.. just tune well and hope for the best..
$750 L98
Feb 1, 2025 02:25 PM
seiplentz
Aug 19, 2019 06:02 PM
customblackbird
Oct 1, 2015 04:30 PM
Dragonsys
Sep 25, 2015 03:51 PM
Doobie52
Sep 11, 2015 06:19 PM
