P1SC crank pulley wobble
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I finally got her fired up and all sounds good, but looking under the car at the blower pulley it has a slight wobble. Balancer is true, serp pulley is true but the balancer pulley is moving around. I notice the 3 bolt holes for the procharger unit has 2 round ones and 1 oval. is this intended for something? Any solution to fix this?
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Car: Formula
Engine: 6.0 LSX
Awesome advise. I took off everything and noticed the spacer rocked a little in the crank pulley. I kinda used a short chisel and went around that small area where you guys lathed. Sorta peeled it like a apple. Got a small amoutn of shavings off this way, tossed it back on. Smooth as silk
bigjay89gta
Oct 15, 2015 08:04 AM
