Blower question
Old Dec 22, 2006 | 02:27 AM
86camedcamaro's Avatar
Transmission: 350 turbo
Blower question
whats the biggist roots style blower that will fit under a 6'' cowl hood? any one know looking at the weiand 144 but it seems to small.
Old Dec 22, 2006 | 02:32 AM
comatose 88 WS6's Avatar
Car: Chevrolegs
i think the blower shop makes one thats 250ci instead of 144 or 177.
Old Dec 22, 2006 | 08:30 AM
hey
will the 250 blower fit under the hood?
Old Dec 22, 2006 | 02:13 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
the 142/144 is supposed to be able to go under a 4" cowl...
What motor is it going on?
If its the 305 the 142/144 is definately enough cfm for that!
To estimate your boost:
25.58 x A x B | C = XXX - 14.7 = boost
A=blower displacement
B=blower drive ratio
C=engine displacement (ci)
So in this case 25.58 x 144 x 1.95 | 305 = 23.55 - 14.7 = 8.85psi boost
More than enough for a little 305!
Old Dec 22, 2006 | 02:56 PM
flrtin1's Avatar
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
A 250 might fit under the hood hera are some shots from my set up with a 144 then a 420.......the white camaro has a BB with a tunnel ram set up but that is a 6" hood
Old Dec 22, 2006 | 03:32 PM
flrtin1's Avatar
Engine: S/B
Here is the 420 with a 2"....like I said a 250 with the right air cleaners should/might fit under a 6" hood
Old Dec 24, 2006 | 09:07 PM
i'm building a 355 but i don't want something crazy sticking out the hood lamo i know they look great and all how much power can a 355 make witha 144 will it be able to handle 450-500 fly? thats one badass car you got there
Old Dec 24, 2006 | 11:45 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
A mild 350 with a 144 shouldnt have a problem with 500 @ the fly
Old Dec 25, 2006 | 12:58 PM
Damon's Avatar
I use the Weiand 142 on my 383 with good heads and a small blower cam. It's making 390 at the rear wheels through an automatic trans using the next-to-highest pulley set available (showing 5PSI boost in the intake). So that's somewhere in the 470HP neighborhood at the flywheel, depending on whose conversion factor you believe. It'll make about as much power on a 350, but the boost would be higher. 500HP seems to be about the lid for the little 142/144 blowers. But you gotta remember that HP happens in a very streetable RPM range with more torque under the curve than any 500HP N/A 350 could ever dream of making.
The larger 177 blower would have greater power potential but it sits the carb about 2" higher. That would be marginal for hood clearance with a 6" cowl hood.
Old Jan 4, 2007 | 12:24 PM
trumps2000's Avatar
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
Hey Damon, did you install the emissions version of this blower? I'm curious to see how the EGR system can be kept intact. I'd love to get a 142, but would like to be able to pass the sniffer test.
Frozer!!!
Jan 19, 2024 04:55 PM
soarestransam
Sep 1, 2015 04:00 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
redmaroz
Aug 16, 2015 11:40 PM
mhatfield 14
Aug 15, 2015 10:47 AM
