Any single turbo guys retain their A/C?
Old Jan 4, 2007 | 08:11 PM
Jeremy_84_F41's Avatar
Car: 1991 Formula L98
Axle/Gears: 3.73:1
I would be interested in seeing one using the factory A/C setup, or even one using an aftermarket system, custom evaporator housing, or otherwise. TPI383 posted up a setup that was for sale that was built around a serpentine A/C setup, but I saw no pictures showing downpipe clearance, which is the main thing I'm curious about.
I wonder if it'd be possible to mount the turbo low and run a downpipe between the engine block and frame rail, then around the starter. Would a tubular k-member give the extra clearance needed to run the downpipe in this area? It seems that the lower down you put things, the less you'd have to worry about A/C box/drier clearance concerns. Just thinking out loud. I've seen a couple guys running downpipes under the k-member but there's no way that would give enough ground clearance for me.
In the end A/C might not be that big of a priority but regardless I'd really love to see if anyone has been successful running it in an application like this.
Old Jan 4, 2007 | 08:19 PM
firstfirebird's Avatar
I'm keeping my A/C (live in FL!) but that does you no good cause the 60degree serpentine belt places the compressor on the other side. If you do some searching using turbo as a key word, I've seen lots of pics on here with single and twin set-ups that retained the A/C and all of it's components.
Old Jan 4, 2007 | 08:23 PM
Axle/Gears: 3.73:1
It was more of a hypothetical question, and anyway if need be brackets can be swapped. I've searched and searched and looked at hundreds of pictures but have yet to see a single turbo setup using the factory A/C system with downpipe routing that didn't go under the k-member. 4thgens seem to have no problem running a turbo on the driver's side while keeping all accessories but I don't think that option is viable on a 3rdgen.
Old Jan 4, 2007 | 08:32 PM
What size down pipe are you talking?! If you mount the turbo in a typical fashion, the down pipe will fit between the k-member and firewall. Again though, I'm using a 60degree V6 so my clearances are a little different, but give me a minute and I'll dig up a pic real quick...
Old Jan 4, 2007 | 08:40 PM
Even though it's twins, the passenger side turbo is where you would want to mount yours and have a crossover pipe in place of the y-pipe.In the power adder forum,
https://www.thirdgen.org/forums/power-adder/399219-high-beam-delete-twin.html
Old Jan 4, 2007 | 09:32 PM
Axle/Gears: 3.73:1
In that pic the drier is missing and it doesn't appear that there is any room for it. That also leaves minimal room for a downpipe.
Old Jan 5, 2007 | 05:45 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Here are some without a AC box in at the time. Im sure you could make it fit no problem.
Thats a 3inch pipe. im sure with a little work you could get it to fit no problem.
Old Jan 5, 2007 | 06:20 PM
What make are those headers/x-over pipes?
Old Jan 5, 2007 | 07:29 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Stock C4 Corvette manifolds. flipped upside down. Custom made rest.
http://www.cecoatings.com/images/Car...r/DSC02715.JPG
Old Jan 6, 2007 | 06:50 AM
vwdave's Avatar
Although I didnt want to, I am going to mount mine forward in the battery trays and probably route the downpipe low.
(TT and AC)
Old Jan 6, 2007 | 08:12 AM
Nice job on the x-over pipe welds! Looks like stainless.
Old Jan 6, 2007 | 04:15 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
yes Sir it is.
Old Jan 6, 2007 | 07:15 PM
yes Sir it is.
I wish my mild steel welds looked that good!
EDIT: You're positioning the downpipe without a j-bend - in other words, the turbo inlet/outlet are 90* apart and aren't you going to have to fit a j-bend in there also?
Old Jan 6, 2007 | 08:53 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
woulda had to do a 90* outa the turbo ya. But I sold that setup and already started on a diff one like this...
http://www.cecoatings.com/images/oth...oCars/preston/
I already have the D.Side header done. Gota start on the P Side now.
evilstuie
Jan 9, 2020 08:29 PM
Street Lethal
Aug 14, 2015 08:25 PM
BikeFarm
Aug 11, 2015 11:35 PM
