what turbo should i use
Old Jan 17, 2007 | 01:15 PM
LoneStar666's Avatar
Car: 2005 Pontiac GTO
Engine: 364ci LS2
Transmission: 6 speed
Axle/Gears: 3.46
i am now taking a remote mount turbo setup into consideration... what type/size of turbo should i use if i only want to run somewhere in the ballpark of 5-6psi? Id have the turbo mounted back right before the muffler, or right at the end of the y-pipe... depending on which one would be easier to cover up from water splashing on it
also, with a high output fuel pump, and 42lb injectors what else would i need to do to my TPI in order to run 5-6psi on it? would it be safe to run a turbo without a A/F monitor?
Old Jan 17, 2007 | 01:33 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I think the sts kit has a 58mm turbo ( NOT SURE SO.....) All the stuff I read says you should get a wideband o2 ... Also how are you planning on tuneing it ?
Old Jan 17, 2007 | 01:48 PM
Engine: 364ci LS2
Axle/Gears: 3.46
i was just going to slap a tiny turbo on there and generate a little bit of boost, nothing too extreme. i figured as long as my fuel pressure was constant... everything would be gravy?
Old Jan 25, 2007 | 12:19 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
the standard fuel pressure regulator does not compensate for boost, so you'll need a boost referenced regulator. Grab a walbro 340 fuel pump and hotwire kit. 1st link is the hot wire kit, 2nd the pump. You can get them other places as well, just an example.
http://secure.johnsperformance.com/c...ctrical/Gauges
http://secure.johnsperformance.com/c...t=Fuel-Systems
It will be enough for what you intend, also it's plug and play since it's made for the fbody. you will need a new prom as well, it may live with just the increase in fuel pressure, but that is a sure fire way to blow head gaskets. you can also get a wideband fairly cheap nowadays, but again it's not needed. Set it up, take it to a shop that has a wideband. get some data and have a chip burnt accordingly.
HTH!
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
customblackbird
Oct 1, 2015 04:30 PM
New2Chevy
Sep 28, 2015 12:35 AM
