TPI -> Weiand 144
Old Jan 17, 2007 | 06:15 PM
LoneStar666's Avatar
Car: 2005 Pontiac GTO
Engine: 364ci LS2
Transmission: 6 speed
Axle/Gears: 3.46
TPI -> Weiand 144
Ok,
the way things are going in my life right now this is the easiest/cheapest way for me to do any modifications to the intake system... the current intake setup i have is very crappy... huge injectors, and 100% stock tpi.
(i already read the tech article about this i would like some extra help though)
this is what i have come up with so far to do a swap from tpi to the supercharger (jegs part numbers)
Mallory Racing Regulator : MAA-4309 : $75.99
Weiand 144 Low Profile Pro-Street Supercharger Kit : 925-7740-1 : $1709.99
TCI 700R4 Torque Converter Lock-up Kit: 890-376600 : $76.99
What distributor do i need? What carburator should i use?
i already have a MSD 6A ignition and a MSD coil
and would my current 212/218 .440/.454 110*lsa be a camshaft that i could leave in the motor with this supercharger?
and do i have to run a wideband o2 on it
Old Jan 18, 2007 | 11:33 AM
82TransAM_45's Avatar
Car: 82 Trans AM
Transmission: th350 turbo
wideband shouldnt be needed if you are carbed... widebands are for boosted engines that use fuel injection that need basemaps to run properly. im going turbo with a carb in my soon to be built 383 stroker TA. i wont need any wideband o2 sensor. i plan to use a air/fuel ratio guage though, but i should be able to get away using a stock o2 sensor for that since it would technically still be a narrowband motor like for emissions and crap...
Old Jan 18, 2007 | 11:57 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
wideband is always reccommended over regular a/f guages, its more accurate and can help tune the car to run alot better. but its note necessary. as far as carbs, you shouldnt need much more than a holley 600 or 650 for it. I believe just a regular HEI distrubutor will work. that cam should be fine, but you could get a new cam to help make the most power and efficiency out of the blower.
Old Jan 18, 2007 | 01:09 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I think a holley 600 would be dismally undersized for a blown 383. Look at an 800cfm or so.
That cam would work, but would keep you at a low powerband. I'd look at a substantially bigger one. A blower tames your cam, just keep it with a large LSA, and a split pattern, perferably a blower cam.
Old Jan 18, 2007 | 01:39 PM
flrtin1's Avatar
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
That sounds about right Sonix.......Go to page 7 of this Tech Manual ,it gives you the formula to figure out the carb. you need plus some recomendations
ChaseDale3and8
Sep 1, 2015 01:49 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
CORV3TT3
Aug 23, 2015 11:26 AM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
