nitrous on 305 tbi
Old Feb 3, 2007 | 12:02 PM
wannafbody's Avatar
Car: 88 GTA
Axle/Gears: 3.27 9bolt
nitrous on 305 tbi
i know this is kinda out there. But I was just wondering if a stock 305 TBi would hold a 50 or 75 shot. I wont use it much just so I dont get beat by hondas and S10's lol
Old Feb 3, 2007 | 12:14 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
itll hold that with ease just make sure you do a wet shot and make sure you go safe with the fuel jets retard some timing and get colder plugs. you can even do a 125 with ease as i am. i know you can go higher and itll take it but it takes a fuel pump but looks like you just want a small enough shot id say go with a 100 shot plate kit and youll be happy youll be just behind 350z's and vr4's.
Old Feb 3, 2007 | 03:51 PM
wannafbody's Avatar
Car: 88 GTA
I would think a 100 shot would deffinatly smoke a 350z?? they are pretty slow. not sure what a vr4 is
Old Feb 3, 2007 | 05:55 PM
Drac0nic's Avatar
VR-4=3000GT
Old Feb 3, 2007 | 08:11 PM
Engine: LO3
no a 100 shot on an LO3 would not smoke a 350z. im running a 130 shot on my LO3 which has only 50k granny miles before it and with a cat back and open element a 350z stays at my rear bumper the whole race. same with a vr4 not sure if it was stock but a vr4 is a twin turbo all wheel drive 3000gt.
Old Feb 3, 2007 | 09:37 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
Blah, throw a 125 shot at it, a 75 shot is nap-worthy.
Old Feb 4, 2007 | 12:54 AM
Engine: LO3
i second that
Old Feb 4, 2007 | 03:07 AM
wannafbody's Avatar
Car: 88 GTA
what about a L03 with 3.73's posi, tune ( not sure if that will be good for nitrous) and then the 100shot? I think that should be fairly quick setup.... maybe?
Old Feb 4, 2007 | 01:22 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Should be decent, what you run should depend on how well you can get it to hook and the weather/altitude you run in. Full exhaust will definitely wake it up, definitely throw a tune on it and when you want to run the bottle just pull 4* out of the WOT timing curve up top and you should be ok.
Old Feb 4, 2007 | 02:53 PM
Engine: LO3
dont forget 2 step colder plugs might be able to get away with 1 step colder and then higher octane gas 93 works fine but the higher the safer.
Old Feb 4, 2007 | 03:37 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Very true, haha it's been so long that I forgot about putting the plugs in there! Best of luck!
xkingcodex
Feb 12, 2020 07:43 PM
Dwayne614
Sep 28, 2015 08:33 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
CamaroGuy350
Aug 26, 2015 05:11 PM
