749 ECM with 8-10 psi boost
Old Feb 12, 2007 | 10:55 AM
brianjw4's Avatar
I am planning on running a 5.7 TPI single turbo setup with the 749 ECM. My question is if the standard $58 code (with the 8 cylinder constant) will be close as far as VE tables go?
Another question I have is about the 749's wastegate functionality. Does wire up to any electronic boost controller device?
Old Feb 12, 2007 | 09:08 PM
S105.7's Avatar
Car: '87 S10 Blazer & '91 RS
Engine: L98 & L03
Transmission: 700R4 & T5
Axle/Gears: 10 Bolt/3.73/3.42
i am by no means a pro on this, i have only started learning about. anyway, it seems that you can use the delco wastegate solenoid the run an external gate. as for the VE tables, i doubt it depending on your engine build.
Old Feb 13, 2007 | 09:50 AM
brianjw4's Avatar
Thanks for the reply. You are correct about the VE tables.
I used the megatune program to create a VE table based on estimated TQ and HP, while this is only an estimate it was clearly different that the stock table. I'll probably use megatune table values as a starting point.
Old Feb 14, 2007 | 08:01 PM
S105.7's Avatar
Engine: L98 & L03
let me know how you make out with this. i am trying to learn all i can about this. im building a 350 now, and next winter i plan on adding a Masterpower Super 70.
Old Feb 14, 2007 | 09:03 PM
brianjw4's Avatar
I am also planning to use a Master Power T70. I would like room to grow, and this turbo should do the trick. I'm with you on the learning part, I have been reading and reading and I am finally starting to understand this turbo and ECU stuff.
I have been tempted to go the megasquirt route too, but I already bought a 749 from someone on this board. So I'm going to give it a shot.
Old Feb 15, 2007 | 06:00 PM
S105.7's Avatar
Engine: L98 & L03
i was going to buy a '749, but it seems that the '730 with the $58 mask works just the same. im thinking once it all goes together, that i will use the $59 mask thats out there. im not into the megasquirt. for some reason or another, i only like the GM stuff. i guess cause its tried and true, and retains outputs like TCC, A/C, ect.
Old Feb 19, 2007 | 05:48 PM
TurboedTPI's Avatar
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
Just so you guys know, ive had awesome luck with the 749. Just so you know, it can work great.
Old Feb 19, 2007 | 06:35 PM
brianjw4's Avatar
yeah, I read a thread that you replied to on turbomustangs along with the grenade thread and that's why I decided to go with TPI. I hadn't considered TPI until I read how much power was being made with a turbo, unbelievable.
I should be getting my 749 tomorrow and I ordered the V8 memcal so I should be in good shape for getting this thing together. This setup is going in my 69 Camaro.
Old Feb 19, 2007 | 09:40 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Either the 730 or 749 ECM will work with the Syclone $58 code. The two ECMs are the same on the inside. The 749 has one extra fuel injector driver so it can drive Peak and Hold injectors. The 749 is missing one quad output driver for relays & solenoids.
What does all that mean? It means that if you are using saturated injectors (stock TPI type) then you can use a 730 ECM with the $58 boost code. If you are using Peak and Hold injectors and a V6 or V8 then you need a 749 ECM.
For a while I was switching back and fourth using the $8D and $58 code in a 730 ECM with saturated 42#/hr injectors.
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
BBSDesigns
Sep 22, 2015 03:08 PM
eustodp
Sep 20, 2015 05:09 PM
