Nos Jetting Question
Old Feb 14, 2007 | 12:00 AM
90Formula-X-F's Avatar
Car: 90 Formula
Engine: 355 C.I.
Transmission: 5 Speed
I'm installing an under manifold cheater kit under a Stealth Ram. Installed a BBK high volume in-tank pump. Instead of the jet nozzles I've got soft plume foggers going in. I plan on tapping into the fuel rail for my fuel supply and when I power up the pump through the test lead (No vacume at regulator)fuel pressure will be set at 50-55 lbs. if I run #22 nos jets it looks like acording to the jet map that #16 for fuel jets would be about right. Is that correct ?
Any input would be appreciated. Thanx
Old Feb 14, 2007 | 04:13 PM
1bad406's Avatar
Car: 1987 Camaro
Engine: 406
Transmission: Powerglide
Axle/Gears: Moser 31 spline / 4.86
your fuel jets should never be smaller than your nitrous jets. Someone correct me if I'm wrong.
Old Feb 14, 2007 | 05:27 PM
Imthebriman's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
You should never use smaller fuel jets!!! That is just asking the car gods to blow up your car. It would be way to lean when you spray.
Old Feb 14, 2007 | 09:32 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
i believe youre mistaking unless im wrong or am understanding this wrong. but in my NOS instructions on my nitrous kit for my tbi it says with a for a 150 shot i believe it sayss a 65 nitrous jet and a 42 fuel jet are safe very safe running it rich. and that shows the fuel jet smaller than the nitrous.
Old Feb 15, 2007 | 12:37 AM
koolctk's Avatar
Car: 1989 Trans Am GTA
yes it says that the fuel is smaller than the nitrous jet in my NOS 5151 kit.
Old Feb 15, 2007 | 01:28 AM
Car: 90 Formula
Engine: 355 C.I.
Yes, the fuel jets are the smaller of the two. I know there’s some vast knowledge here and I'd really like to tap into it. I don't want a separate fuel source. The nozzles are under the manifold so I want to get the jets as close as possible. I considered an above manifold install but the HSR looks like it was made for an under manifold install with not much room for eight nozzles top side. So …
I know this can’t be written in stone and that I’m going to have to check the burn on the plugs and see where I end up. However once on the bottle fuel pressure drop will play a role in jet sizes. The more drop the bigger the jets. Will I have drop? I guess I can always bring it alive off the car and check for pressure drop but it will be all prettied up and don’t want to mess it up. Before I actually run it I’ll put a protective device on it like a Jacobs or something. Anyway, I’m fully capable of doing the install with 30 years experience as a master tech and fully capable of taking responsibility if it grenades. I don’t want someone to tell me what to do; I’d just like to hear from one of the TPI Nitrous guru’s. Am I where I need to be with 22’s for Nos and 16’s for fuel and start testing from there. Too big on the fuel jets with 16’s ? Anything would be appreciated. Thanx in advance
Rick
They must be taking in considering the injectors adding fuel too. But I don't think you can ever run too rich when spraying.
Old Feb 15, 2007 | 01:30 AM
hey koolctk, That is the TPI plate kit right? how do you like it? What you run in the 1/4?
Old Feb 15, 2007 | 03:01 PM
koolctk's Avatar
I wont say my times, but I can tell you I really like it, especially with ease of intsall.
and I know that people say it makes the 1 and 2 cylinders lean, but thats only if your running a HUGE shot. I am running a 150, many times now and no problems what so ever.
Old Feb 15, 2007 | 04:12 PM
Engine: LO3
the kits for all of our cars are great and are an easy install. depending on the size shot you plan to run bottle pressure will drop how fast depends on the size of the nitrous jet. get a bottle warmer its def worth the extra money.
Old Feb 15, 2007 | 06:00 PM
1bad406's Avatar
Car: 1987 Camaro
Engine: 406
I've ran the cheater plate kit. I guess the TPI setup is different for the fuel as far as jetting wise. I ran a 73 Nitrous pill and an 82 Fuel pill for a 180 shot on mine.
Old Feb 15, 2007 | 08:39 PM
I plan on running a 150 shot on my L98... I hope it puts me in the low 13s... We will just have to wait and see. Has anyone hit the low 13s with spray on a basically stock L98?
Old Feb 15, 2007 | 08:52 PM
koolctk's Avatar
okay I'll say. last night at the drags, a stock L98, and a 150 shot, with very low psi on the bottle (maybe 650 or 700, way too low) went 13.1.
Now I plan to get a bottle heater and I should be in the mid to high 12's.
Old Feb 15, 2007 | 08:54 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
150 shot should be good for 12s, but first put on some headers and true duals/catback to get that added exhaust out of the car
Old Feb 16, 2007 | 12:10 PM
Engine: LO3
sorry for hijacking but what do you think is the biggest shot you think i can run on my LO3? also what size jet?
1992 Trans Am
May 10, 2023 07:19 PM
69 Six Pack
Oct 5, 2015 07:51 PM
fasteddi
Sep 2, 2015 10:29 AM
redmaroz
Aug 16, 2015 11:40 PM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
