Manufactered chips/ cold air induction?
Old Mar 8, 2007 | 03:27 PM
91RSNAVYMAN's Avatar
Car: 1991 Camaro RS
Transmission: stock
Axle/Gears: stock
I was wondering if any of you guys have used or tried any of the million aftermarket chips you can get for just about every engine in the world? Supposedly it tricks your ECM in to thinking that the air is colder, thereby causing ??????? to provide more power for the engine? Is there any cold air induction kits available for a 305 TBI engine? I have seen several 'homemade' type cold air kits online, but not any normal 'bolt-on' types. Also, would these work okay together? As always, thank you for your help!!
Old Mar 8, 2007 | 04:34 PM
B&WIROC's Avatar
my camaro had a aftermarket chip in it when i bought the thing and it's actually worse then the stock chip. they're supposed to trick your computer to thinking its shoving more cold air in "faster" then it really is so it's adding power there and it'll let you get past the speed limiter if you have one. now days though you can program them to do just about anything for you just a matter of coughing up the money. in the end i'd say stick the with stock chip.
Old Mar 8, 2007 | 08:33 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
GM ran the stock bin way rich at wide open throttle. You would be better off with your cold air setup and a stock chip.
Brinkkl2000
Aug 4, 2018 08:29 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
IROCtometal
Sep 2, 2015 02:01 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
kyle5647
Aug 15, 2015 11:56 PM
