i'm just wondering
Old Mar 14, 2007 | 07:54 AM
hotrodZ28's Avatar
Car: 1991 Z28 camaro
Engine: 5.0L 305CID V-8
Transmission: 5 speed
i'm just wondering
does any one thing the factory 305 TPI would handle a turbo without blowin the oil pan off
Old Mar 15, 2007 | 07:06 PM
browncamaroz28's Avatar
Car: 1982 Camaro Z28
Engine: electric
Transmission: powerglide
Axle/Gears: 10 bolt
it will hold 5-7 pounds no problem... when you start going into the 10psi range, internals might be something to look at...
Old Mar 19, 2007 | 08:04 AM
hotrodZ28's Avatar
any certain one u would use?
Old Mar 20, 2007 | 10:48 PM
Engine: electric
Axle/Gears: 10 bolt
Re: i'm just wondering
engine code or turbo? if turbo, something t4 based should work nicely maybe about 45-50lb/min or so... also check this thread out, its about holset turbos, got some good info maybe you can pick up a junkyard dog https://www.thirdgen.org/forums/powe...et-turbos.html
92projectcamaro
Dec 8, 2015 12:25 AM
Bradsaundry
Oct 7, 2015 04:35 PM
loud91rs
Oct 5, 2015 10:05 PM
Bigold4x4
Sep 28, 2015 05:21 PM
