nitrous ?
Old Apr 9, 2007 | 11:53 AM
3rdgen92maro's Avatar
Car: 1995 Firebird Formula
Transmission: Th350/4k stall
Axle/Gears: 10 bolt with 3.42s
nitrous ?
aight guys i got a 1991 z28 with a l98. i bought a NX wet kit from a friend who had it on a 01 cobra. i was wonderin do i hook up the fuel feed to the solenoid from the fuel pressure regulator?
Old Apr 9, 2007 | 12:04 PM
urmomshot77's Avatar
Car: 83 camaro
Engine: 383 stroker
Transmission: TCI 3spd manual
Re: nitrous ?
Yes, but get a T-fitting, so you have a line coming off you regulator and have it split. one line going to your selinoid and the other going to your carburator. And your using an electric pump right? or at least a good after market Mechanical pump??
Old Apr 9, 2007 | 12:19 PM
pairtoe's Avatar
Re: nitrous ?
how big of a shot is it?
Old Apr 9, 2007 | 03:54 PM
Re: nitrous ?
im gonna start with a 75 and see what happens prolly no more than a 125. ill need to take like 4 degrees of timing out right
Old Apr 9, 2007 | 06:51 PM
pairtoe's Avatar
Re: nitrous ?
general rule of thumb is 2 degrees for every 50 hp. but with a 75 shot or lower it doesnt really matter
Old Apr 10, 2007 | 01:29 AM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
Re: nitrous ?
Alot of the manufacturers even say you can run base time even with a 100 shot although I still take 4 degrees just for safety.
Old Apr 10, 2007 | 05:36 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Re: nitrous ?
well since you have TPI, all you do is take the shrader valve out of the fuel test port and screw that line on that goes to the fuel solenoid. then you're ready to rock and roll....since it is coming off the rail, its already regulated to around 45 PSI is what NX recommends for EFI engines. Also i would bump the timing down 2* per 50 hp and work your way back up, checking the plugs after every bump up, allthough i dont see why 75 would need much timing pulled on the tpi, i ran 100 on base timeing in an SD car no prob.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
anesthes
Sep 18, 2015 12:34 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
FlyinLow89
Nov 12, 2001 02:35 AM
vortech305
Mar 30, 2001 12:21 PM
