Twin Turbo Help!!!!!
Old Apr 10, 2007 | 11:37 PM
84350twinturbo's Avatar
Car: 1984 Camaro z28
Engine: 350 TPI Twin T70 turbos
Transmission: th400
Axle/Gears: stock putting in a 9" with 3.89
As some of you know im working on a twin turbo 350 witha turbo 400 trans. my question is does anyone know a good stall converter that can handle 600-700hp or even a blown application i went with a b&m 2500 stall converter and when i got home from summit (which is down the street) the torkmaster that i got says on the side of the box not for use with blown applications. I want one that is a 2500 stall any ideas?
Old Apr 10, 2007 | 11:50 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Re: Twin Turbo Help!!!!!
Boost apps. are a pain to get an off-the-shelf low stall converter. They design them weak and cheap for low stall because they usually go on low HP engines. Boost changes everything. I called TCI about a converter like that and they said they could only do a custom for about $1000. Most turbo converter builders get $500 to $1000 or more. You might try looking into roundy-round racing converters for something off-the-shelf. They are low stall and built for more HP.
Most people at turbomustangs have a custom built from a good shop (not TCI, not B&M, etc).
Old Apr 11, 2007 | 08:10 AM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
mine is from Art Carr a custom converter w/anti-balloon plates.. it wasnt custom built for this engine but my previous 505 and designed for nitrous.. I would think any convertor w/anti-balloon plates would do just fine for you.
Old Apr 11, 2007 | 11:20 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Take a good look at what they use for a stator too.
cheesehomer
Dec 31, 2015 08:48 AM
86Firebird86
Dec 26, 2015 07:21 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
customblackbird
Oct 1, 2015 04:30 PM
