boost recomendations
Old Apr 13, 2007 | 12:51 PM
wilbur1877's Avatar
I just bought a turbo for my camaro the garrett dealer though did not know a place to get exaust for it I made a post in the exhaust forum as well. I am trying to figure out what will be a safe boost level the turbo I purchased is a garrett gt4088R ar .95 housing option. Is there much difference in power in a under the hood set up vs remote mount. my engine is a 327+.030 small journal stock steel crank eagle hbeam rods forged pistons not yet aquired i have world sr torqer II heads edelbrock airgap rpm intake t5 world class no rear end working on mosier 12 bolt or 9". the carb I am looking @ is a demon 650 blow through one site I have seen a lot of guys are using c&s carbs. I know it is a lot of questions any help is greatly appriciated. here are my turbo specs.
*High Performance C117 Compressor and UHP Turbine*Brings GT Ball Bearing performance to the 700Hp class*V-band turbine outlet flange*T4 Turbine Inlet Flange
Horsepower 400 - 700
Displacement 2.0L - 6.0L
Ball bearing
GT4088RCOMPRESSORTURBINE
Turbo
CHRA
751470-1 751450-9751470-2 751450-9751470-3 751450-9751470-4 751450-9
Wh Dia
TrimA/R
Ind
Exd
63.5mm88.0mm520.72 63.5mm88.0mm520.72 63.5mm88.0mm520.72 63.5mm88.0mm520.72
Wh Dia
Trim
A/R
Type
77.0mm 78 0.85 Free Float 77mm 78 0.95 Free Float 77mm 78 1.06 Free Float 77.0mm 78 1.19 Free Float
TURBINE HOUSING OPTIONPart Number448375-18448375-19448375-20448375-21 Wh DiaTrimA/RType --0.85Free Float --0.95Free Float --1.06Free Float --1.19Free Float Oil & Watercooled Bearing
$750 L98
Feb 1, 2025 02:25 PM
seiplentz
Aug 19, 2019 06:02 PM
customblackbird
Oct 1, 2015 04:30 PM
Dragonsys
Sep 25, 2015 03:51 PM
Doobie52
Sep 11, 2015 06:19 PM
