Cam suggestions
Old May 4, 2007 | 03:33 AM
Ivelostcontact's Avatar
Car: 1984 z28 H.O.
Engine: 305 H.O.
Axle/Gears: 10 bolt
Cam suggestions
I just purchased a 84 z28 H.O. (L69) T-5, 3.73's all that fun stuff. I'm getting ready to purchase a holly 600cfm carb, and currently own a Edelbrock peformer rpm intake (borrowing it from my built 350). Was wondering what would be a good cam for this combo, keep in mind this is my ever day car. I'm not really looking for anything that will require chip burnt either due to I have no clue who would do that type of work around here (Huntington, WV), I figure i'll run the 305 to death before swappin the 350 in seeing as how the 305 has 96k on it. Any suggestions?
Old May 4, 2007 | 08:55 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: Cam suggestions
go big or go home... like 108 lsa .520 lift 250+ duration 050 with mechanical rollers...
Old May 5, 2007 | 12:17 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Cam suggestions
Uh yea, but in a more reasonable suggestion...
Try the compxe 256, it's a winner in a 305. Since you have the L69, with the slightly better exhaust, and you have a better intake manifold, 5 speed, and 3.73 gears, there isn't much holding you back from having some real fun. I think a compxe262 would be quite nice - and still very driveable (daily).
Old May 5, 2007 | 02:47 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Re: Cam suggestions
Or the NX262H (comp nitrous HP) http://store.summitracing.com/partde...4&autoview=sku is a great cam off the spray, and if you decide you want more power you can add a nitrous kit and maximize the numbers too.
junkcltr
Aug 2, 2019 11:12 PM
transamgta87
Sep 1, 2015 07:07 PM
camaro71633
Sep 1, 2015 10:24 AM
InfinityShade
Aug 22, 2015 08:00 PM
drathaar907
Aug 6, 2015 04:20 PM
