Dyno Tune Done
Old May 20, 2007 | 08:45 PM
5.7iroc-02ws6's Avatar
Car: 1988 IROC/02 WS6
Engine: zz3 crate w/12 psi ATI and stock ls1
Transmission: 700r4 w/2800 stall and m6
Axle/Gears: 3:42 10 bolt-both cars
Dyno Tune Done
Ed Wright down in Tulsa took care of me w/some custom tuning...
340 rwhp
507 rwtq (some convertor flash--looks like 440-450 across the board)
Both looked real flat and the car drives much better now...
Gotta love that ATI!!
Old May 20, 2007 | 09:14 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: Dyno Tune Done
wow never seen a torque numbers that much higher than HP pretty sweet
Old May 20, 2007 | 09:40 PM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
Re: Dyno Tune Done
why are the #'s so far apart?
Old May 20, 2007 | 09:50 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Re: Dyno Tune Done
my guess in a stock upper TPI intake :S
Old May 20, 2007 | 10:41 PM
Car: 91 RS
Engine: 350 vortec
Re: Dyno Tune Done
ah missed the ATI but still would think you would have more HP than that for 500 rwtq...
Old May 21, 2007 | 07:35 AM
Re: Dyno Tune Done
Like I said... had a spike in torque at over 500... the baseline was about 420-440 across the board..
Old May 21, 2007 | 02:06 PM
Z69's Avatar
Z69
Re: Dyno Tune Done
Converter flash will do that. I saw about a 60 ftlb difference on mine in about 400 rpm when I had mine dyno'd. 430 to 370. It was real obvious with this little hump centered on 2.8k. Which was interesting since I had a 12" 2k rated converter.
Old May 25, 2007 | 10:07 AM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
Re: Dyno Tune Done
sounds off. a zz3 crate is around 300hp, after 12pds of boost it should be up near 475hp or around there. correct me if im wrong.
Old May 25, 2007 | 07:18 PM
Re: Dyno Tune Done
That is rear wheel hp...gotta figure 20% loss for drivetrain or thereabouts... And it is only running about 6-7 actual lbs of boost w/all the mods..
Old May 25, 2007 | 11:21 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Dyno Tune Done
definitely don't consider that converter flash into your RWTQ figure as it's such a quick peak that isn't along a flat torque curve. Although I'd be happy with your numbers, sounds like it needs more boost
Old May 27, 2007 | 03:43 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Re: Dyno Tune Done
I think ....by going by what others post up...that sounds like pretty normal numbers. ( I agree lol more boost heheheheheh)
LT1Formula
Oct 8, 2015 08:34 PM
