Are std TPI fuel rails & reg good enough for turbos
Old Jun 2, 2007 | 11:50 AM
AussieModder's Avatar
Car: 1981 WB Holden Ute
Engine: 5.7 TPI L98 (ex 1991 Z28)
Axle/Gears: 9 Inch Ford LSD 3.82:1 Richmonds
Hi, Im Twin Turboing my '91 350 TPI engine and have everything about ready. Im going to run Bosch 42lb (450cc) green top injectors and a Bosch 044 pump at the standard 3 bar.
The 044 will do 325LPH at 3 Bar and the #42s at 100% duty would require 216LPH so i reckon I have safety margin there.
Will the stock TPI fuel rails and regulator hack the #42s ok at 80%+ duty (ie say 185LPH) ?
Thanks in advance.
-Andy
Old Jun 2, 2007 | 01:49 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Re: Are std TPI fuel rails & reg good enough for turbos
I think that is mroe of an issue wiht the LS1's they got them cheapo fuel rails . TPI's look like billit aluminum to me ...but i am sure others can chime in
Brcharrelson
Aug 26, 2015 07:47 PM
NBrehm
Aug 25, 2015 11:49 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
3rdgenparts
Aug 6, 2015 09:03 AM
