Considering a blower for the 408
Old Feb 15, 2008 | 11:33 AM
  #101
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Re: Considering a blower for the 408
Quick update on my "project". Just purchased the blower, should be here in a week or so.
Called Comp cams, and lo and behold, they recommended the same cam I picked out!! - the NX276HR (part# 12-415-8). Coincidence? -
Old Feb 15, 2008 | 12:44 PM
  #102
allend43's Avatar
Car: corvette
Engine: 406
Transmission: auto
Axle/Gears: 3.55
Here's my combo with 177 weiand @ 210 percent over,406 cu in half fill hard block,deck plugs, Eagle rotating assy w/ srp -21 cc,h-beams,210 afr's, comp 236/242@.050 on a 114 lc, total seal top rings. I use a j&s safeguard ignition but have no detonation retard on 91 pump gas at all. It's traction limited runs, have been 11.30's so far last year, with 1.57 ,spinning, backing off, 60 foots. Going to bigger drag radials or et streets this year. Oh by the way this cam idles 19-20 inches vacuum, sounds like a stocker.
Old Feb 15, 2008 | 01:57 PM
  #103
Confuzed1's Avatar
Car: 83Z28 HO
That's good to hear allend43 - that's a pretty big cam for a blown motor. It's close to what I had N/A as a matter of fact, but ground on a 110 LSA. If it were ground on a 112, I may have tried to reuse it.
If you're getting 19-20" of vacuum at idle with that cam, that's impressive. The cam I picked out is milder (224/236 at .050) - so I hope to idle with just a little "lope".
Old Feb 15, 2008 | 02:09 PM
  #104
allend43's Avatar
Car: corvette
Engine: 406
Transmission: auto
Axle/Gears: 3.55
The blower tames down the idle, plus the added cu. in. tames down the cam too. My powerband is 2000 to 6000rpm. I doubt your cam will have any lope either, but that = stealth!
Old Feb 15, 2008 | 03:26 PM
  #105
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Sounds like a killer setup. Let me know what it makes on the dyno ASAP. I would love to copy/mimic it in my forged 386.
I am looking for more power and am NA right now. I might be PMing you for more advice in the future.
Old Feb 18, 2008 | 03:57 PM
  #106
Confuzed1's Avatar
Car: 83Z28 HO
That's odd.....the power band on my smaller cam is 2000-6000 RPM's also. Weird.
dennisbernal91z : I wouldn't bother with the PM's right away....I have to figure this out myself first! lol Hoping to get around 500 RWHP on the dyno, but it never seems to end up that way. But as I said, we'll see...
Old Feb 18, 2008 | 05:07 PM
  #107
Engine: LS3
I hear ya. The motor I have now is supposed to make 500 Fly HP, but it only makes 340 HP/TQ at the wheels which is like 420 fly. I am not mad though. Car is fast as heck for a DD 3 seasons a year. Wouldn't mind a little more bite down low. This is my first motor and my first car, I am sure I will just keep getting hungry for bigger numbers, but for now I just realy want to see that 500 HP mark with no juice. For now the juice will get me there no problem, haha.
Old Feb 18, 2008 | 07:39 PM
  #108
allend43's Avatar
Car: corvette
Engine: 406
Transmission: auto
Axle/Gears: 3.55
My cam is a solid roller and minus .018 lash puts it probably close to your 224/236 flat tappet as far as duration/power range. I only have 5 degrees timing in the distributor and 27 degrees at the crank for a total of 32 degrees, This also tames the idle and really improves throttle responce and low end torgue, which I really don't need. I can't hook it up with drag radials so I'm going to try street et's this year.
Old Feb 18, 2008 | 09:07 PM
  #109
vwdave's Avatar
Just a quick mention.
Boost pressure in a supercharged application is a measure of resistance in your system.
Basically, the compressor is going to always shoot out the same amount of air per RPM, but the more restrictive your entire setup is, the higher the pressure (and temperatures) are going to be.
Cool thread nevertheless.
Old Feb 18, 2008 | 09:48 PM
  #110
Confuzed1's Avatar
Car: 83Z28 HO
340 HP at the wheels is no sloutch by any means. I got like 387.5 HP with the 400 at the flywheel. And that's with optimal exhaust hooked up, 1/2 the accessories etc...but the torque more than made up for it at 490 ft lbs. - so I know it can breath.
I'm getting a retro-roller, not a flat tappet. The grind is basically a NX267HR hyd roller grind from Compcams. Of course the RPM range of the cam is most likely based on a 350.
Whoa! I don't think anyone's denying the laws of thermodynamics or physics here...it's a measure of resistance in any system. The more efficient the engine is at handling the boost/exhaust, the more "boost" it can take - (but it won't show up as "boost" cause the engine's using it).. I'm hoping it will take enough "boost" to make 500 RWHP..."boost pressure" not being the goal. You know the deal - most power without detonating on premium pump gas with iron heads. My restriction is gonna be my exhaust. 1 5/8 TES primaries with a Hooker 3" catback. But that's why I chose a longer exhaust-than-intake duration cam for boost.
Old Feb 19, 2008 | 11:33 AM
  #111
vwdave's Avatar
I just figured I would mention it is all.
I am more of a turbo guy myself, thats a whole different ballgame in that aspect.
Old Feb 19, 2008 | 01:35 PM
  #112
allend43's Avatar
Car: corvette
Engine: 406
Transmission: auto
Axle/Gears: 3.55
Turbos? We doan need no steenkin turbos! Besides I can't afford one.
codeysabatini
Nov 10, 2015 04:07 PM
86IROC112
Sep 28, 2015 08:17 PM
buckeyecelt
Sep 24, 2015 05:50 AM
mhatfield 14
Aug 15, 2015 10:47 AM
