Double Check My Setup :)
Old Jul 25, 2007 | 08:31 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Here is the Schematic I drew of my plumbing. You think it would be okay to use the fuel pumps like so? I do not want to spend money on a dedicated Nitrous tank unless I absolutely need to.
Here is the Electrical Schematic I drew up in order to make it function.
I am using a 4PSI safty fuel switch and WOT switch.
I will make my schematic for my Timing Computer and MSD-6AL later.
Any suggestions?
Old Jul 26, 2007 | 11:39 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Double Check My Setup :)
run a mallory 4309 or similar regulator with a return line for the holley blue, you don't want to deadhead these pumps for too long or they can get hot and burn up.
Old Jul 26, 2007 | 02:41 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
I thought this particular pumps were designed for 2 port? That is why the even come with a two port regulator?
Also, If I "Y" split the fuel supply line would two pumps "Y"ed to it be sufficient or do I have to run a whole line back to the tank?
Old Jul 26, 2007 | 04:05 PM
xpndbl3's Avatar
Car: 1984 Z28
since the red is only used during nitrous runs for 30 seconds or so it would not need a return regulator, unless the lines run next to a heat source and would cause vapor lock. I'm sure it's a cost savings thing for the blue to come with a 2 port deadhead considering the mallory is $75 IIRC and the holley blue and regulator is $130-ish last I remember.
customblackbird
Aug 15, 2021 10:16 PM
Infested
May 22, 2018 11:56 PM
redmaroz
Apr 25, 2017 07:14 AM
fbirdroller
Sep 2, 2015 10:27 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
