wat ignition with nitrous
Old Jul 30, 2007 | 09:23 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
i need an ignition thatll have it advanced timing at non nitrous and kick in when i hit my switch for nos. can some11 gimme an msd link?
Old Jul 31, 2007 | 07:01 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Re: wat ignition with nitrous
mallory 685..has start retard, rev limiter, window switch, and a nitrous retard built in and is cheaper than an msd unit.
http://www.jegs.com/webapp/wcs/store...10002_48546_-1
Old Jul 31, 2007 | 07:08 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I just got my MSD digital 6. All that stuff about the mallory is true, but I haate them now. I have a mallory dizzy and had a mallory 6-AL box. Box arrived to my house faulty, and the dizzy has been a bit of a headache. I just hate how I can't get the damn wires on and off without loosening the in cap coil. Also when you install their box, it doesn't come with everything you need. You need to buy little "kits" of wire. I made my own, but still...stupid.
MSD comes with everything you need, including the rubber mounts, everything needed to install in an afternoon. Even a screwdriver to adjust all the *****. Great product and I can't wait to use it.
I also got an MSD billet dizzy to go along with it. Both parts look amazing.
Old Jul 31, 2007 | 07:19 AM
Car: 91 z28
yeah if money that tight, then go with the digital 6 and a window switch. The only reason i went that route was because i already had the pro-billet dizzy and a window switch, but everyone i know that have the 685 like it..never heard anything negative like dennis stated.
Old Jul 31, 2007 | 08:54 AM
Engine: LS3
No I am not saying anything negative about the 685. I am just saying I am kinda pissed at Mallory for sending me a faulty box, thats all.
Old Jul 31, 2007 | 09:01 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
I use an MSD-6AL and MSD Timing Computer.
Not really cost effective but for both look to spend $500 or so
Old Jul 31, 2007 | 10:17 AM
Engine: LS3
not too bad. I spent $320 on my digital box.
Is the timing computer better/more adjustable than the digital box?
Is it true that for every 50 HP of N20 you pull one degree of timing?
Old Jul 31, 2007 | 12:37 PM
Imthebriman's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
I heard that for every 25 after 75hp you have to retard it 2*..... may be incorrect though....
Old Jul 31, 2007 | 02:19 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
well I just need something that will retard the timing when i hit my 100 shot and stay advanced otherwise. Its(the nitrous) trigured by a button on my hurst shifter. So that will work with the msd 6 I assume? Now if i were to get that mallory, I would have to get a mallory coil instead of the msd I have too then right? I just recntly bought the car with the nitrous and I'm gettin this bad boy ready for my nitrous.
Old Jul 31, 2007 | 02:43 PM
I have heard good things about the mallory unit.... do you have the remote mount coil? if so I don't believe that you need to change the coil....
Old Jul 31, 2007 | 03:47 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
A knock sensor simulator activated by the nitrous button would cause the ECM to retard timing. It would be cheap too.
Old Jul 31, 2007 | 10:52 PM
i never thought of this.... know of anyone who has done this????
Old Jul 31, 2007 | 11:18 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
does sound pretty snazzy
Old Aug 1, 2007 | 12:00 AM
junkcltr's Avatar
Engine: 3xx ci tubo
I don't know of a commercial unit that is available, but I simulate the knock sensor on my ECM testbench all the time. Maybe you can find someone selling one associated with the megasquirt stuff. I don't sell stuff. I do it in my spare time for fun.
Old Aug 1, 2007 | 04:05 AM
Car: 91 z28
For those of you who were curious the rule of thumb (but not in every case) is 2* per 50hp shot, or of course 1* PER 25hp. This is just to get a general idea, though checking you're plugs and running a wideband would be the best method for obvious reasons.
Old Aug 1, 2007 | 07:11 AM
Engine: LS3
Thanks for the rule of thumb. I will remeber that. i am starting off with a 150, so I guess i will dial in 3* for now and tell my wideband to data log the shot to see how I do. Thanks. By this time next week I should have all my ign. stuff in and my first try at N20. Can't wait to post what i think. haha. Later
-Dennis
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
92projectcamaro
Sep 24, 2015 08:09 AM
94ElBanditoDeCa
Aftermarket Product Review
Sep 23, 2015 09:05 PM
RedLeader289
Sep 23, 2015 06:50 AM
