Turbo measurements... what is it?
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
I've got a turbo here with the following measurements:
Compressor - 56trim
-60.3mm inducer
-80.5mm exducer
Turbine - 74trim
-74mm inducer
-63.5mm exducer
The compressor housing has a 4" inlet with a 2.5" outlet (t04s?)
The turbine has a t3 flange with a 3" outlet
I don't know the A/R's, could someone explain to me how to measure them?
Any ideas what it is and if it'll work on a stock 305tpi in a single setup?
Pictures:
http://www.mattodoom.com/turbogta/turboid/IMG_1295.JPG
http://www.mattodoom.com/turbogta/turboid/IMG_1296.JPG
http://www.mattodoom.com/turbogta/turboid/IMG_1297.JPG
http://www.mattodoom.com/turbogta/turboid/IMG_1298.JPG
Compressor - 56trim
-60.3mm inducer
-80.5mm exducer
Turbine - 74trim
-74mm inducer
-63.5mm exducer
Pictures:
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Re: Turbo measurements... what is it?
Here's a good link:
http://www.moddedmustangs.com/forums...rim-vt730.html
and the z28tt page where I calc'd my turbos...
http://www.skulte.com/z28tt/archives...harger_sp.html
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I would have expected about 80 - 82% VE max. at 6000 RPM with most V8 turbo cams.
It seems with the high VE and low IAT estimates your lb/min is much higher than actual. Did you do the VE calcs to see where you are at after you had the engine running or is it really at over 600 FWHP at 5 PSI?
Engine: 3xx ci tubo
Compressor - 56trim
-60.3mm inducer
-80.5mm exducer
Turbine - 74trim
-74mm inducer
-63.5mm exducer
Compressor - 56trim
-60.3mm inducer
-80.5mm exducer
Turbine - 74trim
-74mm inducer
-63.5mm exducer
A/R = area/radius. Measure the area of the two turbine inlet holes. Then measure from the exhaust wheel center to the turbine inlet center to get the radius. Divide the two numbers.
With that compressor and a T4 turbine with a decent A/R it should work great on a stock 305 TPI.
Supporter/Moderator
Car: '89 Z28tt
I'll need to re-visit the calcs when I get a chance. I think the temp drop may have come from the intercooler core specs from Spearco - they had a chart w/ charge airflow vs efficiency with a few curves depending on the velocity of the ambient airflow. Good chance the VE was optimistic. Looking back on the dyno results (http://www.skulte.com/z28tt/archives/engine/) I see 520 rwhp @ 6psi. I wish I had a chance to instrument everything, get turbo shaft speeds, before/after temps, before/after egt's, etc. Cam is 236/230 on a 113 LS with AFR 210 heads and 399 cid, so it's not too wild, but has a bit of a lope. My aim was to keep the sky high backpressure from reverting the charge.
Engine: 3xx ci tubo
With the good heads, a mid-230's cam, and 399ci it probably was up around 85% VE at 6000 RPM. That is a bigger cam than I was expecting. I figured it had a 21X to 22X duration cam with a 110 - 114 LCA.
With a properly sized Spearco you will have IATs down around 110* F. Overall, I would say that your calcs are pretty good. Maybe only 5% high on VE which doesn't change things a whole bunch. That is a nice setup you have there.
New2Chevy
Sep 28, 2015 12:35 AM
74mm, 805mm, ar, car, charger, compressor, housing, measure, measurements, measurments, mesuring, mm, rating, turbo, turbos
