Heavy turbo headers and alum heads
Old Aug 17, 2007 | 09:59 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
Maybe im just being overly cautious but has anyone had any problems hanging a heavy turbo header and turbo off of an aluminum head with the standard SBC exhaust flange bolt pattern? Didnt know if the heads would strip out or ?
Old Aug 17, 2007 | 10:08 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
Re: Heavy turbo headers and alum heads
we did tensile testing on 1/4" aluminum plates with 1/4-20 threads in college. It took over 4500lbs to strip the threads. So if you get some longer header bolts (I use 1" bolts through a 3/8" flange = 5/8" of thread engagement) the bolt head will most likely break off before the threads strip out. I have heard of a rule of thumb to go by: thread the bolt in to a depth equal to the diameter of the bolt. In my case its threaded more, 5/8" of thread on a 3/8" diameter bolt.
Old Aug 17, 2007 | 10:30 PM
MattODoom's Avatar
Car: '88 G T/A
So its not really much of a problem at all then haha.
Old Sep 11, 2007 | 12:01 AM
83 Crossfire TA's Avatar
you get full strength in steel with 3 full threads engaged, in aluminum with 5.
WRT to the actual question, tensile strength isn’t the only question, engines vibrate and that vibration causes the weight hanging off the fastener to act like a hammer, slowly hammering out and loosening the threads. OTOH, it’s probably not a significant problem till the fastener comes loose allowing for a moment arm to get a bit of a swing at the job…
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Street Lethal
Apr 30, 2019 12:14 PM
86White_T/A305
Aug 17, 2015 12:16 AM
TreDeClaw
Aug 14, 2015 06:58 PM
MENINBLK
Aug 5, 2015 11:58 PM
