Turbo selection...I did a search, oddball questions
Old Sep 8, 2007 | 05:36 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I have a 350 now, specs are in my sig. I'm taking the blower off because I'm bored and looking for a project.
I did a search to see what people are using for single turbo setups on a 350. Unfortunatly I didn't find anything specific for what I would like to do.
I would like to make 8-12 psi thru a 3" core air-air IC with a max RPM of 5500. Obviously with a redline this low I want the turbo to spool as quick as possible.
Any suggestions? I've been looking at turbos here http://www.atpturbo.com
Old Sep 8, 2007 | 09:29 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: Turbo selection...I did a search, oddball questions
just search for the S400... should be around $590-600
Old Sep 8, 2007 | 11:46 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
A stock $600 S400 is not what you want if you want it to spool fast and rev to 5500 RPM. A modified S400 for $1300 will spool quicker. The larger the turbo, the heavier the wheel and the slower it will spool. Something in the T62-T70 or GT37-GT42 range is more suited to your application.
Old Sep 9, 2007 | 08:37 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Don't forget the JYD stuff...
Holset HX40/HX55
Old Sep 10, 2007 | 02:01 AM
Car: Bee-Bowdy
Axle/Gears: fo-tins
Does anyone have good info on the Hitachi HT-18S? I can't find any useful info thru google. The info I did find tells me it's very similar to a T3.
Old Sep 16, 2007 | 12:44 PM
Drac0nic's Avatar
If it's similar to a T3, forget it unless you have a pair. I wouldn't want anything I couldn't measure the inducer diameter on to get a rough idea of it's capabilities. While it doesn't tell everything, it's a good part of the story.
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
fasteddi
Sep 2, 2015 10:29 AM
PestilenceIV
Aug 20, 2015 03:32 PM
redmaroz
Aug 16, 2015 11:40 PM
antares57
Aug 6, 2015 07:47 AM
