Nitrous Nozzle location for TPI
Old Sep 17, 2007 | 06:49 PM
1wheelwonder's Avatar
I'm sure others have wondered this if not developed an answer for this question. I would like to know where or how you guys with Maf equipped TPI cars are installing or placing the Nitrous nozzle. I realize plate kits are out there which would be a whole lot simpler but I have a EFI kit from a previous build. I thought about placing the nozzle on the factory coulper from the TB to the Maf but decided it may not hold well.What's everyone doing for this?Thanks Chris (I always search prior to starting a thread) Scronce
Old Sep 17, 2007 | 09:31 PM
Bazookajoe254's Avatar
Car: 86 Firebird
Engine: 2.8 V6
Re: Nitrous Nozzle location for TPI
It would probably be easier if you had an aftermarket/homemade intake tract.
Old Sep 18, 2007 | 06:07 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
i had mine in the rubber coupling, didnt have any problems out of it
Old Sep 19, 2007 | 08:16 AM
Thanks guys
Old Oct 8, 2007 | 06:50 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
thats not a maf setup, thats a map setup. anyone else
Old Oct 8, 2007 | 07:00 PM
jjvette's Avatar
Car: 89 vette
Transmission: a4
Here is the nozzle location on my 89 MAF Vette.
Cheers,
John
Old Oct 8, 2007 | 07:03 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Do you want a plate? I'll sell you mine cheap with 1 nozzle (gave the other one to a friend of mine), comes with the lines to the 'noids, and the throttle/TV cable relocation bracket.
Old Oct 9, 2007 | 02:30 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
I drilled a hole behind the MAF wires and threaded a wet nozzle into the MAF housing itself.
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
Out-Cast
Aug 17, 2015 10:57 AM
Sanjay
Aug 12, 2015 03:41 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
