twin turbo 400
Old Oct 25, 2007 | 08:03 PM
88transam400tpi's Avatar
Car: 88transam/ 86 iroc-z/ 64 corvette
Engine: ta 400ci tpi/ iroc 327 / vette 327
Transmission: ta 5 speed/ iroc 700r4/ vette m-22
Axle/Gears: ta 3:42/ iroc 3:73/ vette 4:11
twin turbo 400
i was wondering is it worth makeing a 400 turbo charged. and would it require a special turbo because of how big the motor is. also what kind of compression ration would this require
Old Oct 25, 2007 | 08:09 PM
PedalToMetal's Avatar
Re: twin turbo 400
Hmm it would take big turbos with lots of lag, also a 400 heats up quick.
Old Oct 25, 2007 | 08:40 PM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
Re: twin turbo 400
Ok.
Yeah its worth turbocharging.
No you wont need any special turbo.
The ideal compression ratio you want will depend on several variables including the octane of fuel youd like to run and amount of boost.
Old Oct 26, 2007 | 10:09 AM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
Re: twin turbo 400
yea...I'd ignore whatever he says...
I'll answer your question with this..
I'm running a 406 sbc, w/twin mp t-70 turbos, 9:1 CR, 10# boost for starters. Runs just fine in this texas heat..can drive in bumper to bumper traffic without overheating.
Old Oct 26, 2007 | 03:54 PM
Re: twin turbo 400
Oh well i was just trying to help, go f*ck yourself *sshole!
Old Oct 26, 2007 | 03:59 PM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
Re: twin turbo 400
thanks for the insight. spoken like someone who doesnt know wtf he's talking about.
<rest snipped>
Last edited by askulte; Nov 3, 2007 at 09:00 AM. Reason: Snipped text adds nothing to this board...
Old Oct 26, 2007 | 04:12 PM
Re: twin turbo 400
<snipped post>
Last edited by askulte; Nov 3, 2007 at 09:00 AM. Reason: Snipped post adds nothing to this board. Grow up.
Old Oct 26, 2007 | 07:33 PM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
Re: twin turbo 400
<snipped>
Last edited by askulte; Nov 3, 2007 at 09:01 AM. Reason: Snipped post adds nothing to this board...
Old Oct 26, 2007 | 08:19 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
Re: twin turbo 400
Originally Posted by BDR
<snipped>
HAHAHAHA! Damn!
Anyway... to answer the original posters question...
Do the 400. There is a guy over at www.theturboforums.com who runs 5.60's in the 8th mile on a FACTORY 400 block. And its a 2-bolt block! And just like him, I would fill it. Im getting my 383 filled.
I would build it with 8.5:1 compression and run an S400 turbo. The guy I mentioned above is running the same turbo.
It appears to me that turbo's are a lot easier on engines than nitrous it. If Im not mistaken, a 5.60 8th mile SHOULD convert to somewhere around an 8 sec 1/4 (correct me guys if I am wrong). Just dont go crazy with the boost and PLEASE stay away from detonation!!!
Last edited by askulte; Nov 3, 2007 at 09:01 AM. Reason: Snipped text adds nothing to this board...
Old Oct 27, 2007 | 10:58 AM
FabricatorX's Avatar
Re: twin turbo 400
Haha is that kid banned yet?
Boosting the 400 can make for lots and lots and lots of fun. Just make sure you pay attention to temperatures and cooling capabilities of your car. Ceramic coating can really help this if it ever becomes a problem. Either a huge single 45r or twin 35r's should do you some good.
Lag isn't really an issue though, just remember that lag only means the engine is running like a stock motor until it hits boost. That's it.
Jimmy
Action RaceFab
Old Oct 27, 2007 | 10:23 PM
DPSJosh's Avatar
Car: 1987 Trans Am
Engine: Forged 383 with Brodix Heads
Transmission: Pro-Built TH400
Axle/Gears: 9-Bolt 4.11s with Posi
Re: twin turbo 400
A 400 would spool a 101mm turbo quite nicely. :-D
PS- A stall and a transbrake will destroy almost any tire coming out of the hole, lol. Leaving the line at 15psi coming from a 101 = 1000ft wheelstand.
Old Oct 28, 2007 | 12:14 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Re: twin turbo 400
What kind of 101mm turbo? A 101mm exh exducer is giant. Yeah it will wheelie off the line at 6000 RPM when it is finally spooled. Are you talking about a 101mm inducer that has little to do with boost?
Old Nov 1, 2007 | 11:24 PM
Re: twin turbo 400
ok thanks for all the good info. i am going to do my homework on this and make my choice
Old Nov 3, 2007 | 09:08 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Re: twin turbo 400
Allright... I've gotten lots of PM's about this topic, and edited out the threats and insults which do nothing for this board or topic, other than make it look like a bunch of 14 year olds in junior high. Grow up.
The power adder board has been pretty good about acting like mature adults, helping folks out w/ questions, and generally acting like adults sharing the same passion of HP. If you've got a beef about someone, use the PM's. Don't go be an message board warrior posting threats about having gangs steal someone elses car (at least use the PM's instead if you don't have thick enough skin to just be the bigger person and let it roll off!). Anyways, just grow up.
Everyone's welcome to disagree, and feel free to call someone out on that, but state your reasons in an adult manner, and maybe the other person can learn from that. Pretend you're at work/class/grandparents/whatever, and act that way.
It seems everything is back on topic again, so carry on.
Andris
Last edited by askulte; Nov 3, 2007 at 09:09 AM. Reason: Toddlers need spanks sometimes...
Old Nov 3, 2007 | 10:24 AM
vwdave's Avatar
Re: twin turbo 400
The problem with quick79's build, is he finally toasted the motor on the 5.60 run. Cracked a bore IIRC. That was with a S400 that was modified with the 80mm compressor. The fastest he went with a stock S400 was 5.95's. Which is still flying. You can just buy the S400 from majestic with a 1.30 housing and be ok. I would think a 1.10 would probably be better. Just be ready to run a T6 flange. I would talk to Dave at Majestic and ask him what he suggests.
Im going to be running a single S400 on a 350 Dart. Im probably going to use a T4 .96 housing to decrease lag and move it into the 350's powerband.
Next thing, to make that thing strong youre going to need to have Dished pistons, head and main studs, if youre planning on a 4-bolt just forget the whole project now. Run a 2-bolt with studs. If you keep the boost down and dont spin the motor really hard it should live for awhile. You can only go so far with a stock block.
cheesehomer
Dec 31, 2015 08:48 AM
86Firebird86
Dec 26, 2015 07:21 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
customblackbird
Oct 1, 2015 04:30 PM
