Carbed Supercharger Question
Old Nov 18, 2007 | 08:41 AM
happydad's Avatar
Car: 86 Corvette
Transmission: 700
Axle/Gears: 3:73 Z51
I'm installing a Powerdyde unit on my 383..I have an ignition question..Keeping the HEI distrib what could I or should I used for a boost timer ??? I'm a little confused on reading MSD's website it seems they want you to use external coil type setup and such...What would work with a HEI so I could adjust the timing in the cockpit like the MSD 5462 ????
Old Nov 18, 2007 | 09:03 AM
Damon's Avatar
Re: Carbed Supercharger Question
If you're talking about a late-model computer controlled small cap HEI system the 5462 will patch into the factory system. See figure 7 of the instruction:
http://www.msdignition.com/pdf/frm23950.pdf
Note that the 5462 is NOT a CD (capacitive discharge) ignition system- it's still inductive, although it is all in one box.
If you're using an earlier large cap non-computer controlled HEI then you are probably better off getting a complete ignition with the boost retard function already built in like the 6462. This system will also work with the computer controlled small cap HEI system. And this one IS a CD system, it's jsut got the boost-retard function built in:
http://www.msdignition.com/ignition_7_6462.htm
Old Nov 18, 2007 | 11:06 AM
happydad's Avatar
Car: 86 Corvette
Transmission: 700
O.K. If I get a 6420 with the HEI harness..No Computer control..Is'nt it still a rev limiter ??? would I have to get an other boost box ??? I did'nt see where is has a vaccum plug to controll the boost....I know I'm missing somethig here
Old Nov 19, 2007 | 06:13 AM
Damon's Avatar
How did the 6420 get in this conversation? It doesn't do boost retard, only rev limiting.
The 6462 I posted about does both boost retard functions and has a rev limiter.
Old Nov 19, 2007 | 07:56 PM
happydad's Avatar
Car: 86 Corvette
Transmission: 700
Gotcha Thanks a Lot
toronto formula
Nov 10, 2015 06:17 AM
theurge
Aug 21, 2015 12:46 PM
PestilenceIV
Aug 20, 2015 03:32 PM
PestilenceIV
Aug 20, 2015 02:33 AM
redmaroz
Aug 16, 2015 11:40 PM
