Good head gaskets for N2O use?
Old Dec 15, 2007 | 08:06 AM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
I'd like to know what some of you recommend for a head gasket for some mild nitrous use. 100-150shot. I know that 150 shot is safe on a stock motor if your careful, so would a felpro performance HG work OK, or should I step up to a copper gasket of some kind?
Old Dec 15, 2007 | 09:52 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: Good head gaskets for N2O use?
I have used Fel-pro for a while with everything with no problems. If you are going above 250 and doing staged hits then you need to look into the copper gaskets and what not.
Old Dec 15, 2007 | 06:38 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Head gaskets act as a nice "fuse" for the rest of the engine.
Example, if you were to put on a dead soft copper head gasket, and o-ring the block, and use head studs, then you'd probably blow the pistons apart from detonation.
Whereas if you have good forged pistons and a normal fel-pro rebuilder gasket in there, that'll blow from detonation before the pistons do ($$$).
A head gasket is cheaper than pistons. I'd rather have that fail, if something was going to fail from detonation.
Normal combustion, including nitrous use, can be contained with a normal head gasket. If you're blowing head gaskets and you're upgrading them, you're just masking the problem, and something more expensive is going to blow next (or the deck surface isn't flat and you need to deck the block/heads).
Also, might want to think about changing that sig, lest you get banned for uttering bad words
Old Dec 15, 2007 | 07:09 PM
Drac0nic's Avatar
As he said, Felpros are OK but I'd probably end up with studs or at the very least new bolts. That is if you've cracked the engine of course, otherwise I would just spray it.
Old Dec 16, 2007 | 05:13 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Felpro MLS. Cant go wrong. I also agree with using studs, or at least some new ARP bolts.
Old Dec 23, 2007 | 11:17 AM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
the "fuse" reasoning is a good one, but in some cases you just need the copper gaskets or they just won't be strong enough. With what you're doing It doesnt sound like you need them anyways though, just a good quality regular type gasket.
If you decide to run a copper gasket though, SCE makes 2 great ones.......they're both self-sealing (they have the printed sealing beads just like regular gaskets around the coolant holes) the regular Titan gasket which requires SS 0-rings (I have those) and theres the Titan ICS (integral combustion seal) which has what amounts to a built in o-ring and doesnt require o-ringing your block.
Old Dec 23, 2007 | 12:06 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
http://www.cometic.com
Old Dec 23, 2007 | 01:18 PM
gary sanders's Avatar
Car: 89 trans am GTA,90 model trans am 350 tuneport,87 firebird
Engine: 355 small block
Transmission: 5 speed,auto 700r4
So i guess my SHIM head gaskets is a bad IDEA? Ive got several passes on the motor with 200 shot,havent seen any problems yet.Im just asking,but I dont use what you call a head gasket,I use the STEEL shims GM factory part number.Maybe because I have an engine built for spray,my compression is greater with the shims.I know they are half as think as a regular head gasket.Piston to valve clearence is real close this way,but it makes some big power numbers that way. Maybe I might need to look in to the other gaskets,dont want to blow an engine!!!
Old Dec 23, 2007 | 11:50 PM
Drac0nic's Avatar
The big gripe I've heard about shim type gaskets is sealing of the water ports, other than that they seal incredibly well. The Buicks run very high levels of boost on stock shim gaskets, as do many other cars. The extra bolts on a 350 compared to the Buicks and Fords make them seal better, so they can go pretty far even on basic gaskets. One guy on another board with a boosted setup was running mid-low 9s on corteco cheapie rebuild style gaskets.
1992 Trans Am
May 10, 2023 07:19 PM
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
NWAsonoma
Aug 18, 2015 05:45 PM
