Linear boost timing master?
Old Jan 6, 2008 | 10:21 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Is the MSD btm linear? Or is it only 1,2, and 3 degrees per pound of boost? Im looking for .5
Old Jan 6, 2008 | 10:57 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Linear boost timing master?
The MSD BTM retards timing by a set amount per PSI of boost. This is set with an on dash **** that is infinatly adjustable up to 3 degrees of retard /PSIG, and to a maximum amount IIRC it was 10 degrees.
Old Jan 7, 2008 | 12:19 AM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Its 15, so by infinitely you mean, I could run .5 or 1.5 degrees per psi, not just 1 or 2 or 3..
Old Jan 7, 2008 | 06:31 PM
Yes, the **** is variable, not detent like a switch would be.
Frozer!!!
Jan 19, 2024 04:55 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
