I might be crazy but, just wondering...
Old Jan 8, 2008 | 11:53 AM
jonarotz's Avatar
Car: 91 Z28
Has anyone ever tried to run one wastegate on a twin turbo setup? I was thinking a cross over between the two headers and a wastegate in the middle.
Old Jan 8, 2008 | 12:17 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: I might be crazy but, just wondering...
Yep, that is actually the recommended way to control boost on a twin set-up.
Reason being is that the crossover can equalize the exhaust pressure pre-turbine, for more equalized boost control between each turbo (good if you are running each turbo on seperate plenums to only half the engine), and also makes sure that both turbine have the exhaust bypassed at the very same instant for better control over shaft speed.
Old Jan 8, 2008 | 01:25 PM
jonarotz's Avatar
Car: 91 Z28
Interesting...I was thinking more as a cost savings effort. It does make sense though.
Old Jan 8, 2008 | 05:25 PM
Might save a little bit of money, but the wastegate will need to be larger using a single wastegate than what each wastegate would be in a dual set-up. These wastegates are generally a little more money being larger.
Old Jan 8, 2008 | 05:29 PM
jonarotz's Avatar
Car: 91 Z28
Right...what size would you reccomend? I am running a low boost like 5psi with a pair of GT66's
Pac J
May 17, 2020 10:44 AM
Rousseau92maro
Feb 1, 2016 05:12 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
Zell1luk
Sep 29, 2015 10:36 AM
