Drivers side down pipe
Old Jan 10, 2008 | 09:34 PM
jonarotz's Avatar
Car: 91 Z28
Can you guys help me out? I am looking for some pics of the drivers side down pipe on a twin turbo setup. I'm in the designing stage of fabricating some log style headers and I am having a rough time figuring out what I am going to do about the down pipe on the drivers side. I already figure I am going to have to relocate the prop valve and the oil pressure sender, but I still don't think that's enough.
Old Jan 10, 2008 | 11:28 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Drivers side down pipe
From looking at my own car, looks like the prop valve has to go and maybe a slight dent behind the header and I should be fine. I don't have a bulky oil pressure switch so I can't help you there.
Old Jan 11, 2008 | 12:54 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
89JYturbo had some pics of a twin setup with log manifolds around here somewhere. He had Volvo T3s so the outlet was 2.25". I am not sure if he ran 2.25" DPs or stepped them up to 2.5". A search for his username should bring up the pics. He had pics both in and out of the car.
Old Jan 11, 2008 | 07:43 AM
jonarotz's Avatar
Car: 91 Z28
I've seen his and he is using modified stock manifolds. I am going to be using some custom tube headers. His hug the head a little tighter than mine will.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
transaero
Aug 31, 2015 01:14 AM
Street Lethal
Aug 14, 2015 08:25 PM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
