Twin turbo vs Vortech V-1
Old Jan 25, 2008 | 11:28 AM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
I currently have a v-1 supercharger on my car. Im getting about 3 lbs of boost at 3k rpms. Id like to get more boost sooner. A smaller pulley will put me over the top. I've been thinking about a twin turbo setup, could two t3/t4 turbos get me into the boost sooner? Im only looking to run about 10-15 psi, so I think these would be small enough to spool quickly yet deliver enough cfm.
Old Jan 25, 2008 | 02:52 PM
j88l98irocz's Avatar
Car: 88 IROC-Z twin turbo
Engine: forged 383 8-1 compression
Transmission: t56
Axle/Gears: 9in 3.50's trac loc moser axles
Re: Twin turbo vs Vortech V-1
it should definitely come into boost sooner with twins, my pro charger didn't start boosting until 3,000 rpms. The twin turbo setup I am using now comes into boost at 2000 rpms
Old Jan 25, 2008 | 03:23 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Wow, any turbo lag? What turbos are you using?
Old Jan 25, 2008 | 10:14 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
You have me curious. I have two .48 A/R T3 turbines on a 305ci that starts to make boost at 1700 RPM. I love the low boost setups. What size ci, cam, intake, heads, and turbines are you making positive boost at 2000 RPM?
Old Jan 26, 2008 | 10:07 AM
Transmission: t56
its Im using the 800 horsepower gale banks twin turbo kit the car is not running right at this point with #60 and a stock ecm the 2000 rpms was just an estimate but I definitely notice the boost sooner with the turbos vs the supercharger.
383 eagle forged crank, eagle h-beam rods, speed pro pistons, com custom ground turbo cam, patriot 210cc aluminum
heads, jesel 1.6 shaft mount roller rockers, mini ram. ect ect
Old Jan 26, 2008 | 12:46 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Pics....?
Old Jan 26, 2008 | 02:49 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
I was just reading about the Tom Nelson 1500hp 406ci twin turbo engine built for the Hot Rod Magazine "F-Bomb" car. Absolutley amazing. Super streetable. Way more power than Im willing to tune my chassis for. I think I will ditch my supercharger next year, get an aftermarket block, better carb, and convert to twin turbo. Most of the fun is building it, the driving is just a nice side effect.
Old Jan 26, 2008 | 06:03 PM
Transmission: t56
I have a thread under check out my new power adder!!! check it out
Old Jan 27, 2008 | 09:35 AM
^ Just now came across it, awesome setup man....!
Old Jan 27, 2008 | 10:50 AM
Transmission: t56
thanks I appreciate that man
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
customblackbird
Oct 1, 2015 04:30 PM
anesthes
Sep 30, 2015 07:48 AM
