Max compression for NO2?
Old Feb 3, 2008 | 07:36 PM
91RS/SR355's Avatar
Does anyone have an idea of how much compression I can run in a 355 4bolt sbc if I choose to use nitrous. I'd only be looking for about a 100-150 shot on top of a 10.5:1 500 hp engine w/an HSR. Is that safe?
Old Feb 3, 2008 | 07:45 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
Re: Max compression for NO2?
You will be fine with aluminum heads. and pump gas just pull some timing out and step the plugs down a heat range or even two steps down make sure you have good fuel pressure and dont run extended tip plugs also gap them .035 to .030.And to answer your ? I have seen 15-1 motors running two fogger set ups.
Old Feb 3, 2008 | 07:48 PM
87v6baby's Avatar
Car: 87 camaro
Engine: 2.8 stroked to 3.1 fully built
Transmission: t-5 5spd manual
i dont have an exact answer but i have been using nitrous for awhile now and with what you have i prolly wouldnt go any higher then 11:1 but i believe you should be ok and safe to run up to a 12:1 ratio
Old Feb 3, 2008 | 08:04 PM
91RS/SR355's Avatar
Im actually running GMPP Iron heads (I guess the paint job worked). Do you think thatd still be ok? Thanks for the quick responses.
Old Feb 3, 2008 | 08:13 PM
87v6baby's Avatar
Car: 87 camaro
yeah i still think you should be fine. just private message me if you have any other questions about setting up your nitrous.
Old Feb 3, 2008 | 08:14 PM
91RS/SR355's Avatar
ok. Thanks a lot.
Old Feb 3, 2008 | 08:17 PM
87v6baby's Avatar
Car: 87 camaro
no problem bro, have fun but be safe
Old Feb 4, 2008 | 05:17 AM
83 Crossfire TA's Avatar
Whatever you can get away with NA with _NO_ detonation should be OK with spray
Old Feb 4, 2008 | 09:33 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
You'll be using what, 94 octane NA then? 10.5:1 on iron heads?
Then you probably want race fuel with the spray.
Old Feb 4, 2008 | 06:59 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
With iron heads you will be at the raged edge. I would mix or do as I have done in the past put in a seperate fuel system for the nitrous and run good fuel when you spray it.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
FormulasOnly
Jul 23, 2018 08:47 AM
92projectcamaro
Sep 29, 2015 07:07 PM
Gordonr1973
Sep 29, 2015 11:59 AM
WhteRbt
Sep 21, 2015 09:48 AM
