Turbo 350 setup
Old Feb 7, 2008 | 06:33 PM
metalman3797's Avatar
Turbo 350 setup
I was looking to do a turbo setup. What would be better for the track a twin turbo or a single turbo? What are the advantages of each? Also What carb and heads do you recommend?
Old Feb 7, 2008 | 11:07 PM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Re: Turbo 350 setup
whats the specs on the build? CSU will hook you up with an awesome carb, and any of the major brands of heads out there will do fine, of course, aluminum is always better.
Old Feb 7, 2008 | 11:33 PM
Re: Turbo 350 setup
I just have the block. Its a 10/10 block. I didnt know if i should go 2 T4's or one big one. I have a forged crank already, everything else i still need to get. Need heads, blow through carb, pistons and rods.
Old Feb 9, 2008 | 12:49 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Re: Turbo 350 setup
Check this link out, and read up on it a bit, it will give you some great food for thought about building a turbo set up, and pointing you in the right direction as far as carb choice.
http://www.theturboforums.com/smf/in...topic=101273.0
Old Feb 9, 2008 | 02:02 PM
Re: Turbo 350 setup
Thanks a lot
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Apr 30, 2019 12:14 PM
camaro71633
Sep 1, 2015 10:24 AM
Eric-86sc
Aug 24, 2015 09:01 PM
crazynights
Aug 21, 2015 06:53 AM
