Crower Rods
Old Feb 8, 2008 | 09:24 PM
XxSgtReillyxX89's Avatar
Car: 91 Trans Bird
Engine: 3.1 MFI
Axle/Gears: Stock
Crower Rods
I wanna know if i just got a deal or what i just bought 6" Crower rods for my 350 for $70 is that a deal or no
Old Feb 8, 2008 | 09:28 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Transmission: Powerglide
Axle/Gears: 3.55
Re: Crower Rods
h beam yes i beam ok but not great
Old Feb 8, 2008 | 10:07 PM
2fast4u92z's Avatar
Car: 2 camaros 1 trailblazer SS
Engine: 346twinturbo, 383tpi
Transmission: t56 and 700r4
Axle/Gears: 3:46 4:11
Re: Crower Rods
Need more specs! mine where a ton more but are H-beam forged.
Old Feb 13, 2008 | 01:52 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Crower Rods
Any rods for $70 are a good deal.
Rods are always forged.
I beams go for $200 or so, crower probably more.
H beams are even more money, so whatever you got, you won on that deal. Unless they're cracked
Old Feb 13, 2008 | 10:16 PM
2fast4u92z's Avatar
Re: Crower Rods
Not true I know a motor that has aluminum rods. Don't last more than 2-3 track days. And end up paper weights when they stretch. Also can realy damage heads. But help a little old SBC make 870hp N/A.
Old Feb 13, 2008 | 10:32 PM
Sonix's Avatar
Car: 1982 Trans-Am
Re: Crower Rods
Ok, I was talking about normal rods. The exceptions to my rules are aluminum and titanium
Old Feb 14, 2008 | 05:40 PM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
Re: Crower Rods
What rods are you using??? We used to run 1 pass top fule rods in our TA/FC....wouuld run them 50 1/8 mile passes then remeasure usually got 150 passes out of a set. Our 14-71 blown alcohol sbc 400(1400 dyno hp by the way) would run an entire season on a set of CROWER aluminums and then only got changed for good measure.
Old Feb 16, 2008 | 12:30 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Re: Crower Rods
It might be a good deal if your putting them in an engine that doesnt make a whole lot of power. Id have to wonder why you got them so cheap, unless it was out of a race car that just changes the rods every so often for insurance. If they're going in a powerful motor, Id like to have the peace of mind and get them checked out by a machinist. Said and done after that cost you could almost get some decent I-beams, which is all most people need anyway. Not H.
Old Feb 16, 2008 | 01:43 PM
2fast4u92z's Avatar
Re: Crower Rods
Not crower rods. And we where in a class(don't want to give any or than that). It was cheap insurance and see only had one motor and the rules are very firm on motor specs. This is a motor has no blower or turbo or nitrous. But is HIGH compression. We learned many things in the last 2years. Like we lowered the octane and picked up power. Also run the same oil in the car all year. And added a vacuum pump. Please understand 900hp N/A with a SBC and a single (750) carb is not that easy. And yes we have run the rods a full season before. Car ran a 9.28@143 at a race weight or 3200lb. The car has been sold and the motor sets in the garage. Don't know what I want to do with it.
It no longer has aluminum or steel rods, however is still 300hp to much for my 3rd gen.
Old Feb 16, 2008 | 02:03 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Re: Crower Rods
Wow that takes some skill. Thumbs up to you. If you need any help finding a home for that engine, Im highly qualified to take it off your hands.
You can keep the cam if you want.
Old Feb 17, 2008 | 06:30 AM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
Re: Crower Rods
You can find good I beam rods also look around.
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
skinny z
Oct 5, 2015 06:23 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
