150 shot/ now it claters
Old Feb 10, 2008 | 09:57 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Transmission: custom 700r
Axle/Gears: moser 9" 3.90
i just recently purchased a nitrous kit.
i installed kit per directions
started with 75hp jets
sprayed it monitored afr all chcked good
100hp jets installed 4*retard and all checked good
150 jets installed 6*retard the afr went extmely rich and started poping thru exhaust
now engine claters under medium load never did this before.
it still has all its power though.
do you think i hurt something or maybe the plugs just fouled out or something
Old Feb 11, 2008 | 12:26 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: 150 shot/ now it claters
how rich did the AFR go? is it a rod knock noise? what is a "clater" ?
how do the plugs look? did you go 1 or 2 step colder on the plugs when spraying the 150 shot?
Old Feb 11, 2008 | 01:23 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Pop the valve covers and check that stuff first, that's easiest.
Maybe help us help you - tell us what the heck this is even installed on eh? Year, engine size, induction style, carb model, etc etc?!?
Old Feb 11, 2008 | 05:40 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
its a 350
lunati 60101 cam
810 casting on the heads
hsr intake
accel 24lbhr injectors
commander 950 ecu
it clatters like if you have bad gas but only under medium load light throtle
it doesnt do it at idle or anything
the o2 read like .98v
the plugs were bosch 7575 and there are toast now hoping thats all it is seems like its got a dead hole nowthe plugs were brownish red with heavy deposits
Old Feb 11, 2008 | 05:45 PM
Sonix's Avatar
Car: 1982 Trans-Am
Hmm, probably just plugged up a few plugs and it misfired = rich.
Change the plugs and go from there. Hopefully it was just the plugs (crosses fingers)
Old Feb 11, 2008 | 06:46 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
i def hope so thanks for being optimistic man
Old Feb 12, 2008 | 01:15 AM
xpndbl3's Avatar
Car: 1984 Z28
i hope you're not tuning off a narrowband 02 on nitrous instead of a wideband 02. wow.
Old Feb 12, 2008 | 07:29 AM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
yeah its a narowband
Old Feb 12, 2008 | 05:11 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Old Feb 12, 2008 | 05:35 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
well i am not trying to tune the kit yet jets installed are the factory calibrated jets. nothing wrong with a nb o2 theres plenty of people using nitrous that dont have anyway to monitor there afr so i dont know why yall are making a big deal about it
Old Feb 12, 2008 | 05:54 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
I would say that it is dangerous at the 150 shot level. Especially with cast pistons. Just trying to warn you man.
Old Feb 12, 2008 | 06:05 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
i do have a wideband butt its its in the mail going back to holley ause it took a crap. i want to stick with delco plugs so does a R42T sound right?
if the plugs arent the problem its gona get beat on to make room for my 383 that was gonna go in my corv8
Old Feb 12, 2008 | 06:52 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
clatter with medium engine load after nitrous use is usually a sign of broken rocker(s) and/or wiped out flat tappet cam lobe(s).
Old Feb 12, 2008 | 07:04 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
broken rockers how would it break them. they are stock stamped rockers
Old Feb 12, 2008 | 07:10 PM
stock stamped steel is exactly why they would break...lot of flex and not made to any kind of strict tolerances, its GM in the '80s what do you expect?
Old Feb 12, 2008 | 07:26 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
i wont be able to use 1.6 rollers on the stock heads will i
with out work to the valve guides rigt
the 1.6s will put me at .483in .499ex
Old Feb 12, 2008 | 10:31 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Might want to post that somewhere where somebody that knows what a 810 casting is will see it.
Old Feb 12, 2008 | 11:23 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
well wouldnt you beable to hear that at idle and light part throttle? i would think a broken rocker arm is somethign that would stand out...lol
Old Feb 12, 2008 | 11:43 PM
Sonix's Avatar
Car: 1982 Trans-Am
WHOA! Ok, .499" lift on 810 (like 193) heads?!? Guide work done?
A "clatter" sounds lighter than a bottom end noise, that's why I suggested checking the valvetrain. It's SUPER EASY to remove valve covers, you can see if any rockers broke, if any studs started to pull out, and you can run the engine (briefly) and see if any lifters aren't moving as much (wiped cam).
So.... you try it yet? Nothing to lose...
Old Feb 13, 2008 | 12:08 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Check the muffler for a broken baffle and or the cat for a broken core.
Check the exhaust system for a leak (collector gasket).
Check the torque converter/flywheel bolts and the ring gear welds.
Look for cracks between the flywheel/flexplate crank bolts
Old Feb 13, 2008 | 12:16 AM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Im with you there fbird. If it only happens at an engine load, I would also think its exhaust or drivetrain.
Old Feb 13, 2008 | 12:47 AM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
havnt checked rockers yet, def not exhaust. dont see how it could be drivetrain it sounds exactly like clatter from bad gas. its only undr medium load its nice and smooth under wot
Old Feb 13, 2008 | 09:59 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
should i use r42tl's or 43's with my 150 shot
Old Feb 13, 2008 | 10:20 PM
xpndbl3's Avatar
Car: 1984 Z28
2 steps colder from stock
Old Feb 15, 2008 | 01:10 AM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
lets say that it is a rod noise that would be from a spun bearing right? and if that were the case the there would be metal in the oil correct?
Old Feb 15, 2008 | 09:05 AM
Sonix's Avatar
Car: 1982 Trans-Am
Yes. You could drain the oil and cut open the filter and check for metal. However it might be from bearings or it might be from camshaft or from... etc etc.
Have you checked the easy stuff first though? hell, have you checked ANYTHING that we've recommended in the last few days??
Old Feb 15, 2008 | 11:17 AM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
ive been out of town and just barely getting to mess with it
no metal in oil or filter will post anything i find
appriciate the help guys
Old Feb 15, 2008 | 04:06 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
well i changed the plugs r42ts
still has a lope as if theres a dead hole
pulled vc's no broken rockers and all appear to have the same amount or movement wile engine runs.
so im thinking its a rod but wouldnt it make noise all the time if that were the case
Old Feb 15, 2008 | 04:11 PM
Sonix's Avatar
Car: 1982 Trans-Am
What did the old plugs look like?
Clamp your timing light on each plug wire in turn to see if it'll flash the timing light. Or pull each plug wire in turn and put a plug in it and hold it against the block to watch it spark.
Got an IR gun? Shoot each header tube after it's been idling for a few minutes. Look for the cold one.
Pull all the plugs, crank engine over with a finger over each plug hole in turn. Find the one that isn't blowing your finger away - ie. not making compression.
Old Feb 15, 2008 | 04:47 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
If your thinking about a hole in the piston, it should be burning a lot of oil, shouldnt it? He said it still has all its power. Probably hammered a bearing. If your oil pressure is the same, then its probably a rod bearing.
But if theres no metal in the oil.....maybe you broke a piston skirt?
Old Feb 15, 2008 | 05:06 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
yeah i think its a rod bearing stacked oil press is same about 30 at idle 62-65 above idle.
so im going to build a 383 with some afr 180 eliminators
Sonix's Avatar
Car: 1982 Trans-Am
It wouldn't be a dead hole if he spun a bearing. It would clatter all the time, and it would be "knocking" more so than "clattering". I know that's more semantics than anything though.
The dead hole part makes me think about ruling out bearings etc. Unless a conn rod BROKE. But I kinda doubt it was major harm for some reason.
Old Feb 15, 2008 | 05:10 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
what kinda noise would a broke ring make?
Old Feb 15, 2008 | 05:12 PM
Sonix's Avatar
Car: 1982 Trans-Am
You might be onto something there. A clatter.
Drive the car around the block a few times. Go home and pull all plugs and check them. If something is wrong with one hole it'll be SUPER obvious by the plugs. And should have been on the old plugs too!
Old Feb 15, 2008 | 05:16 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
it does seem to smoke a little bit more than usual when reved up
when i put the motor together i set the ring gap at i belive 15-17 thous acording to the mfg directions
Old Feb 15, 2008 | 05:32 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Your probably right there, a busted ring would fit all those symptoms.
Old Feb 16, 2008 | 02:55 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
this is so wierd if i activate the nitrous system with the bottle off just fuel the noise will go away!!! butt the afr gauge never reads any richer
Old Feb 16, 2008 | 10:39 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Have you checked the compression yet??
Also does it sound like spark knock?? What is the timing set at??
Old Feb 17, 2008 | 12:26 AM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
the video I posted in this thread is what I broken piston skirt sounded like on mine. didnt do it at idle only at part throttle and WOT.
https://www.thirdgen.org/forums/tech...tml?highlight=
Old Feb 17, 2008 | 06:17 AM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
If I understand you it only claters some of the time? Have you checked the flywheel and torq, converter bolts? I have seen the flywheels break around the mounting flange and make a noise that sounds like a rod knock and the noise will come and go.
Old Feb 17, 2008 | 07:54 AM
ive had that happen too. So theres a vid of that sound floating around here as well. Ive also got a vid of my rod knock and that will sound all the time not just at certain rpm's.
Old Feb 17, 2008 | 11:27 AM
  #42
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
yeah it starts in 3rd above 2500 or anytime at about half throtle under a little load its not as loud at wot butt is faster
i have spark on all 8 cyl and valvetrain is functioning prop. engine still has dead hole it sound pretty close to your vid clip. so im pretty sure its a piston or such considring my small n/a ring gap
Old Feb 24, 2008 | 11:29 PM
  #43
valencia1z's Avatar
Car: 1986 IROC-Z
Engine: 350 5.7 TPI
Transmission: 700R4 2500 stall
check ure converter bolts maybe loose cracked flywheel and if its injected tpi or so does it do it when its first fired up real cold or after it warms up a lil maybe a bad knock sensor mine sounded like the valves whould float or the motor was going to come apart detonating like a rod knock but it was just a dumb knock sensor
no green
Jan 9, 2016 09:22 PM
cmichael
Exterior Parts for Sale
Dec 21, 2015 06:56 PM
darwinprice
17
Oct 11, 2015 11:51 PM
1nastygta
Sep 24, 2015 08:58 AM
Eric-86sc
Sep 22, 2015 08:25 PM
