twin turbo headers on ebay .. $144
Old Feb 21, 2008 | 07:59 PM
Adrians91Z28's Avatar
Car: 91 Camaro Z28 Convt.
Engine: 305 TPI (built)
Transmission: 5 spd
Axle/Gears: 3.08 posi
was looking around ebay and found these twin turbo headers ..
http://cgi.ebay.com/ebaymotors/Small...spagenameZWDVW
they look similar to the banks headers ..
would they work on our f-body tpi camaros ..
what is a "rough" list of other parts to complete a twin turbo setup
thanks ..
Old Feb 21, 2008 | 08:28 PM
84bandit's Avatar
Re: twin turbo headers on ebay .. $144
man it seems like this question gets answered every day. ok, ill be nice and not yell FOR NOT USING SEARCH!
those will work, for a while, if you support the turbo, otherwise the heat will turn them into a leaking piece of junk.
now for the list of parts
wastegates
blow off valves, oil lines, fittings, etc
lots of tubing
intercooler?
water methane? depends on what u want to run
v band clamps
downpipe
o2 sensor (preferably wideband, but if ur broke, or cheap, or a gambler, us a narrow band like me about a fifth of the cost)
boost gauge
a complete fuel system overhaul, boost referenced
a prom, injectors
or a blowthru prepped carb
and a pile of money for everythingi forgot, or that u need as u build it.
Old Feb 21, 2008 | 08:41 PM
Transmission: 5 spd
yea .. i tried using the search but nothing came up .. guess it wasnt working for a second or something ..
neways ..
i looked around a few pages and found a couple more of these types of questions .. saw they make a "kit" with these headers for $1000
how much of a gain could i expect with a twin turbo setup on my 305 tpi ..
i just built the motor with summit racing vortec heads, comp 501 cam, edelbrock hi flow intake, hooker 2055 headers, flat top pistons (but my c/r is about 9:1 b/c of bigger heads), and a complete rebuild / machining crank, etc
right now im thinking it would just be easier to slap on a supercharger kit which is $5000 for the good ones (cheaper ones only support 6 psi on "stock" motor)
but a twin turbo setup is just so damn tempting ..
anyone got an approximate idea of how much it would cost .. found one guy who has over $8K in his and still isnt done ..
Old Feb 21, 2008 | 08:42 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
no those will mount the turbos through the hood, they are too tall.
Old Feb 22, 2008 | 12:33 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
If you want to place the turbos there buy a set of used corvette C4 stock headers and weld a new flange to them, they will be lower.
/N.
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Drone358
Dec 10, 2015 08:16 PM
Ian Irvine
Sep 4, 2015 08:08 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
